Transcraft trailer
Discussion in 'Flatbed Trucking Forum' started by cowboy655, Apr 20, 2015.
  1. cowboy655
    cowboy655 Bobtail Member
    20
    4
    Apr 10, 2015
    The company I work for has a transcraft super beam trailer double axle and double beams does anybody got an idea of what the maxx weight it can handle is. Got a press part that weighs 63000lbs trying to figure out if the trailer will handle it
    Thanks
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    How long is the piece? I probably would put it on and not worry about it.
  4. cowboy655
    20
    4
    Apr 10, 2015
    Ya its not that long 15 ft I think still going to have to have over weight permets going to put me around 83000
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Look at plate with VIN stamped on it, Gross wt. that your trailer is built to haul will be stamped on it most are 80,000 but fleet type may only have 60 or 70,000 frame rating?
  6. cowboy655
    20
    4
    Apr 10, 2015
    ya I tried that the plate is wore out to the point I can't read it
  7. Rontonio
    Rontonio Road Train Member
    6,251
    45,413
    Aug 9, 2009
    You only weigh 20000 empty?
  8. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    you are going to need more axles. the trailer probably weighs around nine to ten thousand pounds alone and your truck is going to weigh around 22 23 so that would put you closer to 96 thousand then 83,000
  9. As someone who owns a transcraft. Unless you are running a triaxle. I would not suggest putting that 63,000lb 15' long press. On a spread or close tandum.
    The trailer will not last, if not crack in front of your first trailer axle from weight.. Due to the design, The trailer has a tendency to. " hammock swing" with heavy short loads. The frame& axle connections don't do well to metal fatigue. Or swinging as you drive down the road.
    Just a heads up
    How wide is this press? Will it touch both frame rails on the deck?
  10. The Admiral
    894
    561
    Jul 18, 2010
    Akron,Ohio
    It depends what states you are going to be in as far as whether or not you can get permits. A good many of those trailers are rated at over 70,000# in 4'. For a one time load I would not worry about the trailer. You do want the piece supported by the main beam. Your may have to use 4X4's or 6X6's between the floor and the piece.
  11. cowboy655
    20
    4
    Apr 10, 2015
    Ya will use 4x4's always do, don't have exact measurements yet but its around 15ft long and 6 ft wide going to ky from ga
