Trailer tandem length
Discussion in 'Questions From New Drivers' started by LouisFred54, Apr 25, 2017.
  1. LouisFred54
    LouisFred54 Light Load Member
    63
    43
    Apr 25, 2017
    say you're driving a load through states that require different tandem regulations (but not delivering there, just passing through). You want to keep your load weight even but don't want to stop before each state just to slide tandems. Is this unrealistic or something to question?
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    Unrealistic.. Set it legal for shortest state and leave it alone.
    Especially if it's heavy.
    I only move them if it's light and under special circumstances. Like really light going through Wyoming or something.
  4. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    If you can't set it to a length that is legal in every state you needed to travel through get it reworked
  5. Brandt
    Brandt Road Train Member
    4,405
    5,939
    Sep 17, 2012
    California has the shortest length low. So if you loading in Maine you set trailer to California law and make sure they load you legal before leaving. If not they have to reload the trailer.
    The trick for California is tell shipper to load trailer just like a 48 feet trailer. You should have 5 feet of empty space in back of trailer.
    DoneYourWay Thanks this.
  6. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Most states have a maximum distance usually measured kingpin to center or rear axle group or kingpin to center of rear axle. Also keep in mind Maryland and maybe others I am not sure, have a no more than 35% rear overhang rule. So if you slide them all the way forward you may be in violation for that.
    If you are live loading you should have an idea of how to tell them you want it loaded. You should be in the habit of asking how heavy roughly each pallet is and how many pallets you are getting and the total weight. From that you can draw up a plan in your head as how to load it. This way you should always be able to get it legal by sliding axles rather than having them have to rework the entire load.
