Trailer seems to bounce when applying service brakes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Edjahman, Jun 28, 2021.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hi
    I have a 2015 Utility dry van that just had the brake shoes replaced.
    I noticed this morning when I was driving empty to go pickup a load that it seemed to bounce when applying the service brakes.
    Maybe it's just my imagination or something. Something just seems wrong.
    Maybe shocks?
    Thank you
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Could be that the brake shoes and drums
    Are not worn in (bedded in) and also new friction material is grabby and brakes are probably adjusted up tighter than tractor brakes. That is usually the case. Give them a few days snd it will settle down
    Edjahman Thanks this.
  4. jason6541
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    If you haven’t replaced shocks recently like in the last year it would be a good idea.
  5. Edjahman
    648
    444
    Apr 2, 2013
    Thank you
  6. Edjahman
    648
    444
    Apr 2, 2013
    Thank you
  7. 201
    201 Road Train Member
    12,052
    24,605
    Apr 16, 2014
    high plains colorado
    Couple loaded panic stops should take care of it,,,:eek:
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I have trailers transferred in here with those type problems. They often have the wrong drum and or brake shoes. Did not replace cam bushings as needed.
    Hope a little running and proper adjustment works for you.
    Call the people that did the work and ask them their opinion. Then there is a record of it.
