In my truck all lights works perfectly, in the trailer turn signals and stop lights work just fine but running/tail lights don’t work!
I checked all the fuses related to this and they’re all good, on my pigtail I don’t have any power in the brown wire.
Any advice will be really appreciated!!
Trailer running/tail lights not working!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ReneJRR, Oct 25, 2018.
In a bind we used to put a jumper between the brown an black wires.
Folks need more info about your truck for other advise.ReneJRR and Diesel Dave Thank this. -
Lol... I followed a truck for over 100 miles a couple of nights ago that had this same problem... Tried hollering at them over the CB, no response. Just so happens that they were also stopping in Walcott, IA so I follwed them into the truck stop and told the driver about the problem before I went to park for the night.
Test the pins where the pigtail connects to truck. If you have power there on the pin that goes to brown wire in pigtail, then all you need to do is buy a new pigtail. If no power the issue is in the truck. Id bet that the brown wire is broken inside the pigtail. -
ReneJRR Thanks this.
Had that problem recently. No power from the truck for clearance lights, markers on trailer.
Fuse was blown, and kept blowing. So I knew I had a short.
Took me about two hours to find it was the lisence plate light assembly that had the short. Easy to fix at least.ReneJRR Thanks this.
