I'm considering buying a 2015 Vanguard dry van. I have read the mixed reviews of Vanguard on this forum, but the thing giving the most pause on this particular trailer is a few holes in the roof. The dealer will be repairing those. But how effective are roof repatches or repairs? Is having a couple holes a sign that more will follow? I'm in the PNW, so rain is certainly is an issue.
Trailer roof leak repairs on used trailer
Discussion in 'Ask An Owner Operator' started by audax81, Apr 23, 2020.
audax81 Thanks this.
ZVar and Rideandrepair Thank this.
I have no idea, must be from damage, either forklift or trees.? The way you asked the question made Me wonder. Obviously if you don’t damage it in the future, you shoudnt need it repaired.
Rideandrepair Thanks this.
They have some super sealer, usually grey or black, if they use plenty of it, till you can see it squishing out inside. The patch won’t leak. Might want to keep some quick patch aluminum foil/ sticky sealer stuff? Don’t know what it’s called, Lol. Good for emergency repairs.
Doing household getting a hole in roof is not a common all the time thing. But it's also not big deal. I've had hole fixed both by truckstop and trailer repair place. I've also helped other guys seal it ourselves with a patch and roofing tar from lowes. So I would say if hole is from trees and not accident or topping a bridge. No big delays fix it and go.
Clean up the suspect area good with some Soft Scrub and a brush and hose off good.
I suggest marine 5200 sealant because I have used it for decades and it is bullet proof .
If it's raining and you see a leak you can pump it into the crack and it will stay being its thick and will cure being that water actually speeds up the curing process.
You can buy the little tubes at Home improvement stores. The cartridges online or West Marine.
