Trailer repair - spray coating to prevent leakage?
Discussion in 'Ask An Owner Operator' started by carwreck, Feb 25, 2012.
  1. carwreck
    carwreck Light Load Member
    155
    46
    Feb 11, 2010
    Chicago, IL
    Hello,
    I'm sure others on here had the same problems I have with my trailers.
    I have 2 53' dryvans. One is a 99 and the other 98. both have floor leaks, where they get some moisture and or some water inside when driving in the rain. Is there some sort of coating that I can spray underneath to prevent leakage?
  3. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    Spray-on rubbercoat like Rhino-shield,etc. Lots of commercial outfits out there.
    Mommas_money_maker and carwreck Thank this.
  4. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    Where do I find that? is it sprayable or brush?
    thank you for the advice
  5. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    I have used the 3M brand with good results and pretty reasonably priced. Just a regular spray can and seals really good.
    Here's a link for it: [ame]http://www.amazon.com/3M-Automotive-MMM8881-Undercoating-Oz/dp/B0002NUO5Q[/ame]
  6. free2frog
    free2frog Medium Load Member
    437
    155
    Sep 15, 2009
    Indianapolis, Indiana
    Check out the nearest Wabash trailer repair shop I use to run dedicated parts for them they have a complete floor refinishing kit that seals the floor. No idea on the price though.
    carwreck Thanks this.
  7. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    A trailer shop near where I live told me about a product called Key Polymer brand Floor restore. Last I checked, a complete kit with filler for gouges, and the sealer was about $400. 1 kit will do 1 53' trailer. It is applied on the inside. I plan to do this to two of my trailers.
    http://www.keyfloorrestore.com/
  8. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    This sounds like an excellent option. a little pricey, but might have to make that move soon. I will first experiment with this rubberized coating from Rustoleum. bought a few cans and will spray in some test areas underneath. will post updates
    thanks to all for your valuable info
  9. Dino1968
    Dino1968 Light Load Member
    My local service guy has a process they use for this. They clean the floor really well,than put resin on the floor in liquid form. Then they spread it all over the floor
    and let it dry. Usually they'll put some sand in it too, otherwise it will make your floor real slick. The last one I had him do, I think he charged $600 for everything. That trailer was having leakage problems at the front, right above the drives. And foodgrade shippers don't usually load trailers that have 4 ft diameter puddles of water ! The resin treatment took care of the problem 100 % Best $600 I could have spent on it.
  10. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    ....until some dihspit nails a few boards to the floor to hold a pallet or two in place....:biggrin_25516:
    86scotty and Farmerbob1 Thank this.
  11. carwreck
    155
    46
    Feb 11, 2010
    Chicago, IL
    sounds like a reasonable price! last quote I had was 1000!
    what state is running out of?
