Hi, I have a 2005 Hilbilt XL dump trailer that now has most of the frame crossmembers rusted out, the side frame rails are also rusted through. Just wondering if anyone else has run into this? If so was it reparable or am I looking at a complete rebuild? Has Hilbilt stood behind any repairs? This is so bad I am really afraid to use the trailer anymore. Thank's for any info
Trailer Question, Hilbilt XL
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckbiz, Oct 19, 2010.
Wow, five years old seems real early for frame rails and cross members to be rusted through. We used to pull Trans-Craft flat beds that aren't the top of the line by any means and they wouldn't need frame work until they were over 10 years old. We prolly get about the same or more winter salt here.
Bill -
this trailer was used for hauling something aggressive, may be with acid.
Yeah, dump trailers may have welded frames that may be repared welding sections in. But you will loose payload capasity anyway.
Check also ABS unit, brakes, brake lines, wiring...
But my advice- sale it for any price... -
Seeing as how you're in the Chicagoland area I bet you've hauled salt with it and/or driven in the winter with it. I think the XL was the 'hybrid' with the steel frame and aluminum sidewalls...bad combo as aluminum against steel corrodes and add to it hauling salt and driving through it....
Gambi80, you are exactly right, steel frame aluminum sides & floor. I didn't go into all the details, but I know of two other trailers in the same condition. One I know of was rebuilt to the tune of $13000.00!!! new side rails and all new crossmembers. Both '05 models, Hilbilt has a real design problem here and I'm trying to find out if they are doing anything to address it.
Oh yeah, the rusting I've seen is nowhere near the al. steel contact areas. -
Do you drive it in the winter or no? If you do and also haul salt with it...that's just asking for rust. Have you gone back to where you bought it from if you bought new?
I've got an '09 Pitboss and won't let that thing anywhere near salt...steel trailer would be just asking for a big pile of rust...but that doesn't have the crossmembers like you've got...just a tub with associated 1/4 frame draft arms/linkage. -
Truckbiz! Can you post some pics? It is so difficult to say how to repare and prevent rust damage If we can't see shots.
Good idea, may take me a couple days.
