Is that the actual name of it? And can you identify this dirty muhfuggah without a part number? It's a 2008 Benson 524a, and I'm pretty sure it's Hendrickson suspension. Anywho, it was leaking all my air out the exhaust. Wouldn't build past 90, and wouldn't release the brakes. Like any good oilfield hand, I hit it with a hammer, and it started working.
Bonus points if you can tell me WTF the black thing is in the last two pics. Thanks.![]()
Trailer pressure protection valve
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by God prefers Diesels, Mar 3, 2021.
I have seen those but do not recall working on one. Some things to thank about.
1: It is connected directly to an air tank.
2: It has a blue and red air line to the top of it.
3: It has four other lines. Are they outlets that go to the spring side of 4 brake chambers?
4: What is the problem with it?
5: Guess that is a parking brake valve without more info. Easily converted to a more common valve parking or service. Many valves are replaced first because of a bad chamber.
The black box is a tracking devise from the IRS, CIA and or FBI. Ha! I have no idea.God prefers Diesels Thanks this. -
black box is a tracker
BoxCarKidd, God prefers Diesels and black_dog106 Thank this. -
BoxCarKidd Thanks this. -
Its a Sealco spring brake valve part # 110700. I was helping with some trailer
rebuilds lately re-plumbing several trailers, new air lines, valves, air tanks
and chambers. The same valves that were very old and corroded from being
near the ocean. They still worked fine. I would replace it myself, not a big
expense and easy to do at home but a pain if it fails on the road.BoxCarKidd, God prefers Diesels and black_dog106 Thank this. -
