Trailer locks
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Mar 20, 2019.
  1. Commuter69
    Commuter69 Road Train Member
    1,133
    625
    Jul 2, 2014
    Most of my shippers/receivers like it when they see me at the trailer door removing a lock when docking, or putting one on when leaving.....
    BUT......
    I am tired of replacing locks because they have gotten so rusted/corroded, that they are useless and unable to (un)lock because of it.....
    Does anyone have a source to a lock that will not corrode? Hopefully with a round barrel key (like one of those heavy $@$#/ u-type bike locks)?
    Links would be great.....
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Use a combination bike lock. Why not? The ones with the big arch should go on easily and with the combo, no key to jam up
  4. Most my locks I have on my flatbed from chain over tarps to lock for boxes or headache rack chains and binders. I spray them regularly with wd40 and some Vaseline in the key hole. To block debris.
    Locks are needing regular maintenance.
  5. Commuter69
    1,133
    625
    Jul 2, 2014
    But those will still corrode in the dials or the knob mechanism... Worse yet, the actual locking mechanism.....
    Looking for one that is either weather proof(not like my first waterproof watch that read 100 m, you would think that meant DOWN, right? Nope..... STRAIGHT LINE! I swam competitively at the time and 2 laps it was full!), OR corrosion proof....
  6. Tb0n3
    Tb0n3 Road Train Member
    4,279
    8,195
    Oct 5, 2012
    Earth
    Abloy PL342. Expensive, but all stainless and brass. You'll see that type on a lot of mega trailers.
    Slowmover1 and PE_T Thank this.
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I only lock when parked .. occasionally I’ll leave it on when weather is dry...
  8. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I go through 1 or 2 a year.... I don't buy the big time locks you can't shoot off with a gun anymore, your decent size master lock is fine. Big enough you can't cut with standard size bolt cutters. Small enough the 36" bolt cutters will cut it off. Costs me like $20/year. For this reason I also quit using those round locks. I don't have a universal opener if it were to eventually jam up.
  10. Commuter69
    1,133
    625
    Jul 2, 2014
    You have a link to a source?
  11. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    just copy/paste the name, etc..i found it.
