Trailer is not straight?
Discussion in 'Ask An Owner Operator' started by jaguar011, Jun 27, 2016.
  1. jaguar011
    jaguar011 Light Load Member
    90
    21
    Jan 28, 2015
    Every trailer I hook up isn't in straight line. I did trailer alignment and there's no changes.
    Can the 5th wheel be a problem?
    And is just adjustment of 5th wheel enough to resolve that problem?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Trailer alignment wont help, your axles are straight with the truck. It's the trailer thats off centered. Need to get it to a trailer shop and thy can get it straight.
    jaguar011 Thanks this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    He said its every trailer he hooks to. Is it when your looking in your mirrors? The perception will make look like its dogging to one side but in reality its going in a straight line
    If your a newer driver just thought I'd tell you that
    CrappieJunkie and LumbraX Thank this.
  5. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    Find some slick concrete like inside a warehouse, sprinkle it very lightly with water then slowly drive straight through it. You'll be able to tell instantly if the trailer is dog-tracking. If not, re-spray and go through bobtail, your drives should track exactly on your steers.
    Or, if your tires are wearing good, truck isn't pulling then just drive, as someone has said, your mirrors will give an optical illusion. On most trucks the right mirror sticks out just a little further from the left and add in that it may be ever so slightly convex then no matter what you align it will appear to be tracking crooked. A sliding tandem trailer is only aligned axle to axle as there is a small amount of play in the slide. That small amount 40' back from the king pin will result in some off-tracking anyway.
    jaguar011, Hammer166 and Dave_in_AZ Thank this.
  6. CruisingAlong
    CruisingAlong Medium Load Member
    374
    441
    Oct 17, 2014
    Tampa , FL
    Is there plenty of grease on 5th wheel? If not, it will cause your trailer to offtrack
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Most roads are crowned, so a perfectly aligned trailer will dogtrack slightly to the right.
    77fib77, jaguar011 and Hammer166 Thank this.
  8. catalinaflyer
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    That's why I always had my fixed spread 3/8" long on the left side, trailer tracked perfectly on a standard crown and a little left on the flat.
  9. drver60021
    drver60021 Light Load Member
    59
    21
    Mar 5, 2013
    He said he did an trailer alignment also? It can possibly be the fifth wheel or on your trucks allignment.
  10. jaguar011
    90
    21
    Jan 28, 2015
    I hooked up 6 trailers until now and every time it dogging on left (driver) side.
    I also tried to do trailer alignment but no changes.
  11. Hammer166
    7,338
    26,313
    Aug 18, 2007
    ~8600+' and loving it!
    Sounds like the drives are not properly aligned to the frame, and the tractor itself is crabbing down the road.
