Trailer hub won't come off!!!!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CFC, Dec 19, 2017.
  1. CFC
    CFC Bobtail Member
    I am tryin to replace wheel seal on Simi trailer and the Drum wI'll not come off. I have the brakes backed off and the tool in canister holding them but no luck . I tried and tried and couldn't get it so I went ahead and pulled axle nut and outer bearing but still can't get Drum off . Please HELP!!
  3. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Just wanted to remind you that wheel seals should be completed in 1 hour tops.
    SAR, wore out and Roberts450 Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Can you you see a gap between drum an shoe, was there a fire in the wheel bearings before you started??
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Never seen anyone pull a hub without removing the spindle nut. Perhaps a manual might be a good place to start?
  6. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    The way you are talking about having the brakes caged it makes me wonder are you talking about the brake drum, or the actual hub assembly?... If you are trying to separate the drum from the hub you can use a 4 pound sledge to hit the drum between the wheel studs (carefully as not to hit the studs themselves) to loosen the drum from the hub. You may have to hit the drum rather hard and repeatedly in multiple spot but it will loosen then you can pull it off by hand. If it is the hub that is stuck in not sure what would be holding it without seeing it myself... Never had a problem once I had response but off, unless the bearings got smoked really bad and welded everything together.... Hope this is of some help.
  7. CFC
    CFC Bobtail Member
    Yes I was talking about the drum.
  8. CFC
    CFC Bobtail Member
    Yeah Thanks
  9. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    You need a BFH tool to get it off. Not a specialty tool, any tool store or even Lowe's carries them. Hell stop your local MAC of Snap on truck and you can get a really expensive BFH tool
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    What kind of hub? Semi trailer is vague. If this is an old inboard drum, you need to knock the studs out to get the drum off.
    wore out and SAR Thank this.
