Trailer has no chute overhead?
Discussion in 'Refrigerated Trucking Forum' started by Qbf594, Sep 14, 2020.
  1. Qbf594
    Qbf594 Road Train Member
    1,641
    8,711
    Aug 15, 2019
    Southern Canadian annex, NY
    2006 carrier ultima xtc on a 2008 utility chassis.
    No chute overhead. Strap tracks on the walls. This is not like the reefers I pulled a few years ago. Floor looks right. Drains and such. But where's the chute? I don't think that is optional is it? Screenshot_20200914-205641_Video Player.jpg
    LoSt_AgAiN Thanks this.
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    If you are looking at that used, get a thermal image of that patch. Good odds you will have a hot spot there that will cause claims in the future.
    (An easy way is simply have the seller cool the inside and you shoot it with an infrared thermometer in several places around and on the patch inside and out when you go to look at it.)
    alds, Snailexpress, Qbf594 and 2 others Thank this.
  4. buzzarddriver
    3,507
    10,013
    Feb 1, 2011
    Dallas, TX
    Looks like those two round silver objects in the ceiling are lights. That may preclude having a chute. Might have been spec'ed for special purpose that didn't require a chute.
    p608 Thanks this.
  5. Qbf594
    1,641
    8,711
    Aug 15, 2019
    Yes 2 lights and the switch inside the back door.
    Maybe I can get mr money to buy the split chute and install
  6. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    You should always be able to install a chute. Look for turnbuckle on the bottom lip of the rectangular hole where the air comes out of the unit. Those are for attaching (particularly detaching easily when removing the unit) the chute. I had a trailer for 17 years with no chute. I never had a load claim, but I primarily hauled potatoes and beer. I did haul other produce occasionally. You just have have to be cautious and let customers know up front there isn't a chute-and confirm with a shipper!! Don't trust when a broker when he says bo chute is fine. You might be driving only to not get loaded. Been there, done that.
    Qbf594, Speed_Drums and alds Thank this.
  7. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Never have had a chute... Haul mostly potatoes but have also hauled eggs, and ice cream without any problems
    Qbf594 Thanks this.
  8. MRMTRANS
    334
    372
    Apr 28, 2015
    BTW...you can always set the unit to run on high cycle for increased air flow and circulation into rear and floor
    Qbf594 Thanks this.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Never had a chute either doing food service. We hauled plenty of frozen back hauls back to the warehouse w/o any issues
    Qbf594 Thanks this.
  10. Qbf594
    1,641
    8,711
    Aug 15, 2019
    Well the 1st load was going to be cabbage...and when even the cabbage people wouldn't load with no chute... we got a chute...lol
    All good. Works fine, happy cabbage happy driver.
    Tx for the insights y'all
    Brettj3876 Thanks this.
  11. MRMTRANS
    334
    372
    Apr 28, 2015
    I am surprised shipper would be picky about cabbage. It is a hearty vegetable-not so air flow sensative, like potatoes. One problem with no chute is temp coming out of the unit-when set at 34-36 degrees-is below freezing around 25 degrees. It can freeze the top layer of the first 2-3 rows of pallets of some produce. Cabbage isn't one of them. It can withstand below 15-20 degrees.
    Qbf594 Thanks this.
