Trailer clearance lights all out
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gokiddogo, May 13, 2014.
  1. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Can't figure this one out.
    My trailer turn signals, brake lights, even abs light comes on as per normal, but none of the clearance/marker lights work. I don't know anything as to how this trailer is wired, or if it has fuses, where to even start. Trailer is a vanguard, year is 2010.
    The other day it did it, and I unplugged the main cord from truck to trailer and plugged it back in and was good to go. Not the same story today. BTW - it is a new cable, only a few months old, if that changes anything ..
    It rained very heavy all day today, if that makes any difference.
    sirrepairsalot and eeb Thank this.
  3. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Check your truck's fuses yet? Many have separate fuses for taillights and marker lights. 'Course if you do have a blown fuse, you then need to figure out why it blew. Possible that one of the lights is full of water, or you have water in the harness somewhere.
    gokiddogo Thanks this.
  4. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Went through that this weekend with our stepdeck and all kinds of broken wiring.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Had this prob on my truck just 2 months ago. Socket pigtail plugged into on truck was orig. rusty and wet from truck wash. Replaced with new and a little dielectric grease. No prob since.
  6. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Well .. fuse panel isn't as simple as I had hoped ... looks like much digging will be required ... it is not the simple little remove and replace as I had hoped ... try it in the morning, I guess ...
  7. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Did yours do the blinkety blink before it quit? Or just totally cut right out one day?
  8. Up74427ca
    Up74427ca Light Load Member
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    You need a new electric wire connect to tractor n trailer because when it get wet in those pigtail,it cause the marker not working,happen to me,I was lazy to mount it and it was raining,so I brought. New wire ,problem solve.good luck.
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Like Bakerman said dielectric grease will put a stop to any moisture problems.
    If the lights flickered then you have a connection issue. New pigtail? Then possibly in the box the wire come loose. Pull the cover off and inspect the connections. If that's not it then possible an exposed wire. It should be a single wire running from the front to the back of the trailer. Perhaps it is exposed close to the frame.
    Go ahead and check the fuse but you need to find the underlying cause.
    What year/model truck? The fuse panel shouldn't be difficult to get to. As far as the pigtail plugged in it should be the black wire at the 10 o'clock position for the marker lights. If you have a DVOM you can check for 12V on that pin or even ohm out the the trailer box pins to ground to see if you have a short.
  10. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    2000 FL classic, detroit 12.7, I plugged into another trailer at the place I am delivering to this morning and the same thing happens - signals, brake lights all work but no marker lights. Have located what I think to be the fuse in question, but its a type of fuse I haven't seen before and the back of it is facing the firewall making it impossible to see (I don't even know what to look for) if it is broken, just going by the diagram on the back of the fuse panel box ... Tried to remove the nut holding on the wire to it, but the wire has been there so long it is welded to the nut - and if I continue the wire will break off right at the eyelet where it connects, and I will be euchred ... hate when something small like this ends up costing much more than it should ...
    If I could get that wire off of there somehow, or bridge the connection to the fuse directly below it, which says it is for the LH headlamp, that would mean it should work, at least enough to get it home, right? Would also tell me my problem ...
  11. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    Always check the easiest/most common thing/problem to fix first, the pigtail connection. It is not at all unlikely the stud terminals on 2 consecutive trailers need to be spread with a small screwdriver.
    Next in my book would come the fuse.
