I learned something new today.
I recovered this trailer at a customer and the trailer has been sittin’ for 7 months. Hooked up to trailer and did my inspection. When I tried to drive away the trailer brakes were stuck completely on both axles. This is how I got them unstuck per our shop mechanic’s advice:
Switch the red glad hand from the truck to the blue glad hand on the trailer. It might not fit but try to get a good seal. Do not connect the other glad hands. The air needs to flow out of the blue glad hand on the trailer. Hop in your truck and release your trailer air supply and wait a couple minutes. This will blow out any debris or bugs that might of worked its way into your airlines. After 5-10 minutes, hook everything back to their normal positions and air up your trailer. This should fix the problem and you’ll be on your way.
If still stuck, just rock back and forth and it’ll break.
I hope this helps if you find yourself in this situation.
Trailer brakes locked up after sitting a couple months?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Smut, Apr 28, 2020.
Sometimes rocking the trailer doesn't work. So then you release the trailer brakes( make sure the tractor brakes are still set) and whack each brake drum with a big hammer. Do not hit the brake shoes just the drum. That usually does the trick.
piston865, Rideandrepair, Caterpillar Cowboy and 3 others Thank this. -
Another way is to wait until your air tanks are completely full of air (air dryer purges), then supply air to the trailer. This high pressure of air can help unstick the brake shoes from the drums. You can also try hitting the drums with a hammer.
I’m starting to think that perhaps another way is to manually force the brake shoes off the drums by turning on the bolt on the back of the slack adjuster.Rideandrepair, Smut and olddog_newtricks Thank this. -
So backing off the slack adjuster would not be effective.
There is no brake cam force exerted to the brake shoes when released.
Only the brake shoe springs retract the shoes from the drum.
Usually the shoes rust to the drums and won’t release.
Hitting the drums as you stated above is usually 99 percent effective to cure a stuck brake shoe issue.stwik, Rideandrepair, Smut and 2 others Thank this. -
Rideandrepair Thanks this.
Rideandrepair and PE_T Thank this.
If space allows and safe to do so, I'll usually back about a foot or so first when hooking on to a long dormant trailer. If that doesn't do the trick it's hammer time!
Shanebklyn and Rideandrepair Thank this. -
And if the guy's a cheapskate that doesn't maintain his equipment you could have seized up cams. Have fun getting those freed up.
Caterpillar Cowboy and Rideandrepair Thank this. -
All good info I hope I’ll never need.
