Trailer brakes, air leaks back thru apply
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Jan 16, 2012.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
  3. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    I don't know if it is a fault but I ran into the same issue when towing a tilt equipment trailer behind a dump.
    I could not keep the trailer brakes from locking under normal braking when empty, so I cut a piece of soda can to block the service line to the trailer (between the glad hands).
    The trailer brakes would apply after a short time due to air leaking over from the supply to the service side.
    I had to disconnect service side and plug truck gladhand to disable trailer brakes.
    I don't know if this is a feature or a defect, as I only tried it on that one trailer to get the stupid thing moved without destroying the tires.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Pull glad hand off and c/k for air coming from trailer glad hands sounds like a relay valve
  5. gafred99
    155
    12
    May 28, 2009
    Tignall
    It maybe a relay valve (it's only a year old, must have been delivered by container ship to US) I unhooked each chamber and tested with brakes released none pushed air out thru service port.
  6. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I see a lot of relays go bad a few months old quality is definitely going down did you check emergency and so the brakes take a while to set like its dumping all the air out of the tanks
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    could it be the tractor protection valve gone bad?
  8. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Need to remove the blue glad hand from the trailer when this happens and see if the air is leaking from the truck or the trailer blue line glad hand. If leak is from truck I would say tractor protection valve.
  9. belltransit
    belltransit Light Load Member
    271
    27
    Jun 28, 2010
    oak grove, mo
    is it only on one trailer or every trailer u hook to? maybe for some odd reason the lines on the trailer are backwards.
  10. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    If its blowing back though the service on the trailer as the video shows it is likely either the service brake relay valve on the trailer or the spring brake valve on the trailer.
  11. gafred99
    155
    12
    May 28, 2009
    Tignall
    It's blowing back thru the blue service port with line disconnected from trailer.
    new valve as you can see in pic... ohh well.
    http://s307.photobucket.com/albums/nn315/bigcrunch69/KentuckyTrailer/?action=view&current=MOV03209.mp4#!oZZ3QQcurrentZZhttp%3A%2F%2Fs307.photobucket.com%2Falbums%2Fnn315%2Fbigcrunch69%2FKentuckyTrailer%2F%3Faction%3Dview%26current%3DDSC03214.jpg
    I hope that is it, checked every brake chamber and nothing coming out of them.
    My stuff sits for periods of time anything I can add to the the air system to help keep rubber parts and other internals in working order?
