Trailer brake locks up when empty
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 24, 2018.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    I noticed one of my trailer axles locks up when empty and smokes tires. What would cause this?
    Ive adjusted brakes on all 4 corners, still doing it. When loaded it doesn't lock up and smoke tires.
  3. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    May have a bad abs sensor or too much gap. Check the wire going to it. May look good and still be bad. If abs light on left rear side of trailer is operable ( or abs trailer light on dash if newer trailer without an abs light on the side) turning key on and off twice then on will flash codes for diagnosis
    mitmaks Thanks this.
  4. mitmaks
    2,542
    2,064
    May 16, 2014
    ok, Ill have them check it out at the shop, there is no ABS light on as far as a I know
    Rideandrepair Thanks this.
  5. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    My trailer brakes lock up when I make a right turn :(
  6. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Plan your routes for all left turns.
    Jazz1, thelushlarry, AModelCat and 7 others Thank this.
  7. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    I would check the length of the pushrods on that axle. Look at the angle of the pushrod relative to the slack adjuster angle. 90° is good. Check the angle of the axle that isn't locking up to compare. Was the trailer recently serviced?
    If it isn't that then it may be an ABS issue.
    I'm no mechanic, just some observations I have seen.
  8. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    My last trailer 01 Great Dane would lock up while empty. Same with a friends reefer seems it’s a common problem very dangerous in rain/ snow.Shop Had no answers already had new ecu . For some reason if I stabbed the brakes hard it would reset something and fix the issue.That trailers where it belongs Parked
  9. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    The real question. Are you in the inside or outside right turn lane when it happens? :)
    tucker and Rideandrepair Thank this.
  10. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    Better be in the right lane !! Lol When making a left which of the 2 left lanes should he be in?
  11. tucker
    12,647
    40,422
    Jun 13, 2008
    IN
    I'm in the outside lane and the trailer tandems are in the inside lane
