Trailer brake lights NOT working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rich_Trucking, Jul 11, 2014.
  1. Rich_Trucking
    Rich_Trucking Light Load Member
    248
    21
    Dec 11, 2012
    Hello everybody,
    I have a 2006 fontaine flatbed trailer and my right brake lights are not working. I had it looked at Wabash and they told me there's a problem with my 09 Cascadia not the trailer. They hooked it up to there machine and the brake lights work fine.
    Any ideas?
    THANKS
  3. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    Same problem with my 1998 KW and it was the trailer brake relay under the hood on the firewall.
    Rich_Trucking Thanks this.
  4. Truck Smarter
    Truck Smarter Bobtail Member
    30
    17
    Jun 26, 2014
    Dallas, Texas
    Check truck fuses and relays. The relay will be labeled and just pull it out. Then pull one of the other relays out and plug it in that place. See if the problem goes away. If not then it is not the relay- except once in all the years I have been doing this. Once- there where two dead relays and I pulled the other one that was dead. Go figure. Now I carry a new relay on my truck and just use it to test.
    If the relay is good and you don't have a blown fuse then the next is to borrow a known good light cord. Swap them and see. From there I would check the plug the cord plugs into on the truck. If the wiring into that plug is good then you are probably chasing a broken or corroded wire. Oh Joy.
    And I would have to check a wiring diagram as I don't know off the top of my head if the trailer brake lights run through the turn signal switch or multi function switch as they call them now on that truck or not but if they do then that is also a possible place to look.
    HTH
    rank and Rich_Trucking Thank this.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    some trucks, like pre 2002 volvo have additional stop light relay for trailer, becouse truck stop lights are combined with turn signals, trailer brake light and turn signals are separated.
    so I sugest truck problem
    check trailer brake output on light connector first
    rank Thanks this.
  6. rank
    9,916
    113,498
    Feb 11, 2010
    Correct. By all means, take your test light or multimeter to verify that there is power going to and coming from the light cord. I should have said this first.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    better use 55 wt bulb. sometimes bad connection lets measure voltage but not enought to light bulb
