Trailer blinker passenger side not working
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Petey786, Aug 23, 2022.
  1. Petey786
    Petey786 Bobtail Member
    I have a 2016 Freightliner Cascadia. For some reason the blinker on the back of the trailer on the right side doesn’t work. Brake light works fine but the blinkers don’t. I changed fuses on the truck and nothing. I know it’s not the trailer because it happens on every trailer I hitch onto. Would anybody have any idea what could be the problem? I’m gonna change the electric port connection to the truck and see if maybe a pin is making connections idk. Any advice would be greatly appreciated and helpful.
    thank you
  3. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    Get a test light an carefully probe the light connector on the truck with the wire disconnected and the right turn signal on. If you find it flashing you need a new wire. If not the wiring issue is deeper in the truck.
    tscottme Thanks this.
  4. Dave_in_AZ
    410,921
    Check the relay for trailer right side turn. If that's not it, the contacts inside the cab chassis controller are probably no good. So you'd need a new cab chassis controller.
    Seen that movie. $2800 with popcorn.
    blairandgretchen Thanks this.
  5. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    It's a fuse up front driver side firewall. Check youtube for video.
    Replaced. I think 20fuse.
    baha Thanks this.
  6. Chieftains
    362
    896
    Jul 18, 2021
    Try this
  7. Powder Joints
    7,874
    8,151
    Sep 25, 2007
    Rosamond, SoCal
    You know there should be a fuse in the box where the trailer pig tail plugs into the trailer, rather a breaker normally.
  8. FYI
    FYI Bobtail Member
    8
    Aug 26, 2019
    Check your truck receptacle or your truck/trailer cord with a test light. Since it follows the truck I'd say that is the most common problem area.
  9. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    yup, i would start at the trailer plug and work forward after checking fuses.
  10. chowblower
    chowblower Bobtail Member
    13
    8
    Nov 18, 2023
    My problem was the relay for the right side in that fuse box
  11. Powder Joints
    7,874
    8,151
    Sep 25, 2007
    Rosamond, SoCal
    At a guess maybe the pigtail between the tractor and the trailer. The T/S's work on the tractor correct. If then is dead work your way toward the fusebox.
