Trailer auto inflation system question
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Jul 29, 2020.
  1. Commuter69
    Commuter69 Road Train Member
    1,133
    625
    Jul 2, 2014
    I just had 2 tires replaced on my trailer and it has an auto inflation system.
    Since the tires were installed, I have an alert to a 'problem' (it would be helpful to have a light for each tire that would indicate which one was the problem child, as opposed to just one light)....
    I pull over and get out, give each tire a thump with my mini sledge. No problem children found, no sounds of a leak.... now I am puzzled.
    Normally, the indicator goes out within 5 rolling miles. Today it took almost 30.
    Any advice?
    Is there a driver level test that we can use to determine if further diagnostics/repairs/maintenance is needed?
    FerrissWheel Thanks this.
  3. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    30 minutes to get it up to pressure usually means a nail or something stuck in a tire. You should be able to hear or feel it. An auto-inflator can fill a completely flat tire in 30 minutes.
  4. Commuter69
    1,133
    625
    Jul 2, 2014
    But I don't hear any leaks?
  5. Antinomian
    2,076
    3,241
    Feb 17, 2013
    Clearly you have one though. Spray soapy water on the treads. You might also try unscrewing the inflator hoses in the morning when you know the pressure will be low and check to see which tire is low.
  6. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    I may be a smart ace here, but use your eyes? May only be barely leaking.
    snowwy Thanks this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If it only did it the one time after getting new tires: the shop may have only put 30 or 50 lbs in the tires , knowing that your inflation system will fill them up the rest of the way.
    I told a shop to do that once, they were busy and I was in a hurry. Trailer was empty, tires were up to pressure by the time I got to load point.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Heck, had one yesterday that had a bolt in the tire and leaking around it. No light at all from the auto inflation system.
  9. Commuter69
    1,133
    625
    Jul 2, 2014
    I didn't have this problem BEFORE the tires were replaced. They were replaced due to wear.
  10. 062
    062 Road Train Member
    6,141
    33,149
    Oct 20, 2013
    One possibility is that the tire shop inflated the tires above the set point of the system. Tiremaxx is supposed to regulate the air to stay within a set range. I don’t know if Meritor does that or not.
  11. Commuter69
    1,133
    625
    Jul 2, 2014
    I think I found the problem children, but need to confirm.....
    Believe it or not, the NEW tires(2 days old), seemed a little low on pressure when left standing for a little bit, not a lot, but I am thinking the shop missed something when they remounted them?
    I am thinking that it's going to be more obvious when cold?
