trailer alignment
Discussion in 'Trucks [ Eighteen Wheelers ]' started by homesick, Jun 18, 2009.
  1. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    my trailer needs an alignment its wearing the tires on the inside.how much will an aligment cost and where can i get it done
  3. 9 Axle
    9 Axle Light Load Member
    147
    23
    Feb 7, 2009
    Purdon, Texas
    Ummmm, care to refine that question? :biggrin_25525:
  4. Crash935
    Crash935 Medium Load Member
    329
    163
    Sep 8, 2007
    Wyoming Mi
    Think hes trying to tell us his trailer has developed a case of "dog trackin".
    Any trailer repair shop should be able to get it pulling straighter. They might need to pull the rails lose and reset them or replace then along with the pins. Shouldnt take them more than a day.
  5. Peanut Butter
    Peanut Butter Road Train Member
    1,343
    419
    Nov 24, 2007
    PO Dunk Idaho
    When sliding tandems make sure truck and trailer are stright, dont slide with truck and trailer in different angles, puts pins in wrong holes and bends rails, hope a shop can fix it for you.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    We charge around $179 or so Canadian. But that isn't for all trailers. That is the standard price for regular two axle torque rod or Hendrikson Quick Align suspensions. It is generally an hour per axle. If you have the welded collar suspension we have had some worst case scenarios of over $1000 due to the time to cut the welds and reweld. Most of the time tire pressure is a big culprit. If you can't see the trailer dog-tracking to one side or the other, check that first.
    25(2)+2 Thanks this.
  7. Bigstretch
    Bigstretch Light Load Member
    161
    30
    Jun 14, 2008
    NW IL
    Check the wheel bearing adjustment as well. If you have an air-ride trailer, might need to replace the shocks.
  8. rjones56
    rjones56 Heavy Load Member
    823
    486
    Jul 15, 2008
    staunton va
    Usually,"dog-tracking" is caused by bent,broken or worn components.If you are mechanically inclined you can ID most of them yourself.A simple alignment shouldn`t take more than a couple of hours at a trailer shop.
