Trailer air bags over-inflated
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wjhuskey, Oct 14, 2020.
  1. wjhuskey
    wjhuskey Bobtail Member
    43
    15
    Nov 1, 2014
    Hopefully I'm posting this in the right area. If not, I apologize.
    I made a 30 mile haul with my Timpte Hopper Bottom trailer this morning. Got back to the farm, got out and the air bags on the trailer were twice as tall as they normally are. Over-inflated. Where do I need to start on fixing this? Thanks in advance.
  3. AModelCat
    154,243
    Leveling valve is where I'd start.
    flood, spsauerland, not4hire and 2 others Thank this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I had same issue at a dock I backed down into . The levelling valve flipped over and inflated bags to max pressure. Be careful I would dump air on trailer and see if it releases air then take apart levelling valve rod and reposition it correctly if it flipped.
  5. wjhuskey
    43
    15
    Nov 1, 2014
    What do I need to do with it...adjust up or down or something?
  6. wjhuskey
    43
    15
    Nov 1, 2014
    Ok will do, thanks. I went into a different grain dumping pit than I've ever been to at this elevator. It wasn't very level and that could be what did it.
    hope not dumb twucker Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Check the exhaust port on the leveling valve for plugged. Inspects can build nests. Especially in seasonal use applications
    spsauerland Thanks this.
  8. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Seen this happen when one axle gets parked in a hole. More common with empty light weight hoppers or tanks. It causes the bag to over extend and it makes it difficult to deflate it and in turn the others inflate to match it instead of them deflating back to normal. You have to pull the main air feed line off and let them deflate all the way down. Make sure they do not fold up abnormally. Than let them air back up and re check the leveling valve adjustment and spring system for leaks.
  9. wjhuskey
    43
    15
    Nov 1, 2014
    Update: I dumped the trailer air 3 different times and it fixed it. Thanks everyone.
  10. Stampede trucking
    Stampede trucking Bobtail Member
    I'm having same issue. My airbags are max inflated. Do u think leveling valve is the problem
  11. Stampede trucking
    When I set trailer park brake the trailer dumps air bags
