Trailer ABS testing.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by xsetra, Mar 17, 2017.
  1. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    To isolate and test trailer abs. Can I disconnect pigtail from truck and run a hotwire from battery to power center pin? Making sure I have a proper ground to tractor.
    Thanks
  3. skro47
    skro47 Light Load Member
    161
    131
    Apr 26, 2014
    Québec Canada
    Yep. I have a spare plug with wires sticking out. Use white wire on the top hole, then test abs with the blue en red wire in the hole directly on the right.
    For diagnostic plug in blue wire for 1 second and take it out and then put it right back in.
    xsetra Thanks this.
  4. xsetra
    5,092
    6,939
    Aug 21, 2011
    I have to apply power to the ABS ,blue wire, and the Brake light circuit, red wire,, at the same time? To do a proper system check.
    The ABS light on the back side of trailer should blink on and stay off, with power up.
    ABS light should stay off when applying power to the brake circuit.?
    Thanks.
  5. skro47
    161
    131
    Apr 26, 2014
    Québec Canada
    One at a time. If the abs light stays on with power on the blue wire its a cut/open wire somewere on trailer. If it stays on with power to the red run diagnostic.
    To get a code plug the blue wire for 1 sec, take it out and put it right back in. Light will pop 1 time and close. After that it will start blinking giving you the code.
    xsetra Thanks this.
  6. xsetra
    5,092
    6,939
    Aug 21, 2011
    1.. power to blue .
    2 abs light blinks on and stays off. All ok.
    3. abs light comes on and stays on. problem in blue wire.
    4 With 1 and 2 above apply power to red wire, abs light comes on and stays on. Problem with abs system. Run diagnostic as described.
    Thanks
  7. kutuzov
    kutuzov Light Load Member
    147
    84
    Apr 13, 2014
    I'm about to test this Monday when I get home. So what exactly do you mean by hot wire?
    My guess is a wire from the -black conector of the batteries. Right the rest I have it all line up.
  8. xsetra
    5,092
    6,939
    Aug 21, 2011
    If your black wire is connected to your POSITIVE battery post (hot wire), than yes. You want a positive feed to your blue wire.
    Usually the battery connections are red (positive) and black (negative/ground)
    good luck.
  9. kutuzov
    147
    84
    Apr 13, 2014
    Nailed it. Gave me 4 blinks on a wanbco. Checked the omhs and voltage of the sensor measures where good for the 2 sensors,so checked continuity for the cable going to the abs unit, and boom was the cable didn't have continuity. Got a new cable and abs is good again.
    Thanks for letting me know how to get the codes!
    Very helpful also:
    http://www.meritorwabco.com/MeritorWABCO_document/mm33.pdf
  10. xsetra
    5,092
    6,939
    Aug 21, 2011
    Thanks to all the advice. Had a speed sensor that was bad and the blue wire in pigtail was corroded.
