Trailer ABS light on. What to look for?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Feb 14, 2019.
  1. PE_T
    PE_T Road Train Member
    This is the second time I got an ABS light. Both happened during winter driving. Could it be because I have never drained my trailer air tanks? This is on a 2019 Utility reefer trailer. I am starting to think this may be covered under the trailer warranty.
    Rideandrepair Thanks this.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Hmm, I’d say no.
    Being new, it’s entirely possible that the wheel bearings are loose.
    Seeing as its weather related, I would think that a weather tight connector isn’t doing its job right. I found a corroded connection on mine last month, water got into the water tight connector joining a wheel sensor to an extension cable going to the ABS controller.
    Rideandrepair and PE_T Thank this.
  4. Rideandrepair
    17,215
    55,893
    Aug 8, 2015
    If light went on and then off. Like it fixed itself, while braking or driving through potholed parking lot.Prbably normal. But if it came on while running down the road, probably a bad wire or sensor, could be loose wheel bearing as mentioned.If you can do a blink test next time it’s on, you can narrow it down to which wheel is affected. Usually cycling the key 2 or 3 times then leaning it in on position and count the blinks. Find out procedure for your Truck/ Trailer, Otherwise Truckstop or dealer can check stored codes
    PE_T Thanks this.
  5. Rideandrepair
    17,215
    55,893
    Aug 8, 2015
  6. Rideandrepair
    17,215
    55,893
    Aug 8, 2015
    I wanted to add, mine had a bad cable also same as Uncleal13. I changed sensor first on both wheels. $50 ea. Then figured out it was cable. Changed both cables from ecu to sensor cable ends. Kept old good 1 for future diagnosis $32 ea. Last week new one got damaged and put old one back on, Lol. Note which valve you have and which way it’s facing front or rear to get proper codes for either side. Otherwise like me you’ll read it as wrong side wheel. wcoastent.com has valve configurations and blink codes. It’s really not very complicated, once you read through how it works. I’d go for easiest cable replacement first, or try pushing sensors in against ring being careful not to damage wiring.
    PE_T Thanks this.
