im about to burn my trailer to the ground as if I'm protesting Gorge Floyd!!! The dang trailer abs light randomly comes on in my dash. It'll stay on sometime 1 hr. Other times all day. This has been going on for months now. I've tried taking it to a shop 3 times. Everytime it turns off while I'm waiting to get called into a bay or literally as I'm driving into the bay. Mechanic tells me it has to be on to check it. Anyone have ANY suggestions or tips. Idk I'm pulling my blad head hair out on this one. Electric cord from truck to trailer is new. Its a 2014 fontaine 48' flatbed if that helps
Trailer abs light on/off troubleshooting
Discussion in 'Ask An Owner Operator' started by Wespipes, May 31, 2020.
I had a problem like that, but mine would also come on and stay on if I hit a bump or it rained. No one could figure it out. I even bought a wire brush to clean my glad hands on the trailer side. That would work occasionally.
Finally a light went off and I checked the tractor side connectors. They were corroded. I change those out and never had that problem again.Wespipes Thanks this. -
Sometimes it was both. Mostly it was on my dash, not trailer.
Or get some more information
https://www.thetruckersreport.com/t.../yellow-abs-light-of-trailer-stays-on.200462/
Dude says in the first 30 seconds, how actual function is affected. Good luck!
I have the same issue and the problem was in bad ground contact in trailer outlet. TA told me that we need a new ABS ECM...
You can get a ABS diagnostic reader and or see if you can get the blink codes, depends on abs system. Have you looked at the tone rings and the Hall effect sensors?. Check the air gap and or bad sensors. Sometimes the sensors are bad or bad connections at the ECU mounted under the relay valve by air tank. Sometimes tone rings on hubs are corroded and or covered in grease. Finally have you checked wheel bearing end play?. If bearings loose it will let air gap deviate from proper setting will sometimes turn on the light.
If you have trailer ABS light on try to read code what is wrong. Turn key on for time less then 5 seconds, then turn off and on again. Trailer ABS lamp will start blinking. Count the blinks and look for the code
https://www.wabco-auto.com/WabcoWeb...2-ABS-and-ESC-Maintenance-Manual.pdf?ext=.pdffree spirited1, RubyEagle and Jenn72 Thank this. -
DeanOfMac Thanks this.
