Trailer Abs does not cycle on/off
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Zekria99, Nov 21, 2022.
  1. Zekria99
    Zekria99 Light Load Member
    75
    8
    Nov 25, 2010
    Toronto,Ontario
    I have a Utility Reefer trailer with Bendix Abs valve. The Abs valve does not cycle on/off/on but when ignition power is applied it just light up. Checked the power it has 13v. Checked the sensor it has above1500 ohms. Could it be the sensor is tossed? I cant get the blink codes because it doesn't cycle no clicks nothing. P
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Trailer ABS doesn't cycle valves. Side ABS light up for short time ti inform you it's powered. If light doesn't cycle with ignition but on every time you depress brake means trailer ABS module energized from brake light and constant power from the truck is lost. Check central wire for +12 volts.
  4. Zekria99
    75
    8
    Nov 25, 2010
    Toronto,Ontario
    The light on the side just powers on at start. It doesn't cycle on and off. It just turns on and stays on. I am not able to pull the blink codes from the side marker.
  5. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Ignition Power Activation
    Ignition Power Activation is the process of using
    the vehicle’s ignition switch (or interrupting the
    power on the blue wire by some other means) to
    display blink codes on the trailer ABS indicator
    lamp located on the side of the trailer. This
    method is for constant power vehicles only.
    To obtain blink codes using ignition power
    activation, perform the following procedure:
    1. Turn the ignition switch on for no longer
    than 5 seconds. The ABS indicator lamp will
    be on.
    2. Turn the ignition switch off. The ABS indicator
    lamp will go out.
    3. Turn the ignition switch on. The ABS indicator
    lamp will then come on, then go out.
    4. The blink code will be displayed three times by
    the ABS indicator lamp on the trailer.
    NOTE: For ignition power activation, power is
    provided by the ignition switch
    Rideandrepair Thanks this.
  6. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    Try unplugging the trailer plug and plugging it in again with the key on.
    That might get the light to flash a code.
  7. Lazer
    Lazer Road Train Member
    1,729
    2,730
    Jan 22, 2017
    Try changing the power cord.
  8. Zekria99
    75
    8
    Nov 25, 2010
    Toronto,Ontario
    So it was the Abs ecu toast because of short on trailer. The trailer Abs solenoids always cycle when you turn the ignition on. Thank you all for your help
  9. Chuckdriver56
    Chuckdriver56 Bobtail Member
    How did you determine that the ABS ecu was toast?
  10. hillfosho
    hillfosho Bobtail Member
    I wanna know also
  11. LongHaulTrailer
    LongHaulTrailer Bobtail Member
    13
    13
    Jul 4, 2024
    Saraland, Alabama
    If the ECU gets its 12V supply but at least one of the connectors for a WSS doesn't read 5V. You're supposed to have a 5V reference going to each sensor. That will cause the light to come on but there won't be any cycling like you'd hear or see.
