tractor with 2 5th wheels
Discussion in 'Questions From New Drivers' started by Freebird135, May 20, 2009.
  1. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    i took this picture a long time ago and forgot all about it
    why does this tractor have 2 5th wheels? and why is the one right up against the cab?
  3. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    I can't see the pic but I'm assuming it's a daycab and probably Yellow. There is a system that allows a truck to connect the dolly to the rear of the truck frame and run it as part of the truck. The first fifth wheel slides up to be out of the way while running it in this conficguration. When you pull doubles you unhook the dolly and slide the first fifth wheel back into place.
    Ducks Thanks this.
  4. rookietrucker
    rookietrucker Trucker Forum STAFF
    10,061
    7,060
    Jul 15, 2007
    TEXAS
    Yep, I think your right. There is a thread around here w/pic of a guy hooking one up. I forgot what the exact name of it.
  5. Dukesdad
    Dukesdad Light Load Member
    137
    380
    Aug 3, 2008
    toronto ontario
    What caught my eye was the tread, or lack of, on the rear tires.
  6. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,584
    Jan 1, 2007
    Southeastern Pennsylvania
    rookietrucker Thanks this.
  7. Freebird135
    1,527
    906
    May 7, 2009
    i dont really understand the point
    in what situation would u need the dolly to join with the tractor? i know u have to pull it around the yard to put in front of your rear trailer when setting up for doubles, but why not just use the pintle?
    i also noticed it looks like theres no tread at all on the dolly tires
  8. L.B.
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    You know I never understood why companies would pay extra for that either unless they use the extra axle on the tractor to haul hevier trailers when not pulling doubles.
  9. Freebird135
    1,527
    906
    May 7, 2009
    ok i think i understand from looking at that other thread
    they keep the dolly locked in like this, and actually pull vans with the 5th wheel of the dolly when it is "jiffed"
    then for example they drop the van at a certain location, and if they need to pick up a set of doubles, they already have a dolly with them? all they have to do is unjif it or whatever and theres the dolly
    is that what its for?
  10. cookie71
    cookie71 Light Load Member
    54
    13
    Jul 4, 2006
    Sunset Beach, Ca
    we use these dollies still, the frame is narrow, it has two heavy alignment pins, and are air ride. I dont like them because you cant see them behind the front trailer when backing them to hook the set.
  11. Crash935
    Crash935 Medium Load Member
    329
    164
    Sep 8, 2007
    Wyoming Mi
    Yup, thats what its for and how its done.
