Tractor---Sleeper Conversion
Discussion in 'Experienced Truckers' Advice' started by rogueunh, Nov 6, 2011.
  1. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    Just curious, if any of you have ever removed a sleeper on an older tractor and converted it to a dump truck?
    The tractor I am thinking about doing it to has a wet kit already, thinking this would be an advantage for this.
    I love the truck, runs great, but would have more use for it as a dump.
    Just wondering how this went for you, if any have done it before. Thanks.
  3. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    I would think the gearing would be all wrong for a dump truck unless it was a tractor spec'ed to pull a dump or transfer trailer . It's also likely you'd need a frame stretch . By the time all the money is spent on the conversion you'd probably have been better off just buying a used dump truck
    rogueunh Thanks this.
  4. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    What you have to consider is.
    1. Most road tractors have 12,000 pound front end. That is not heavy enough for most dump truck applications.
    2. Road tractors generally have single frames. Dump trucks should have a double frame.
  5. cc tanker
    cc tanker Medium Load Member
    361
    214
    Jan 21, 2011
    back years ago I helped a neighbor turn an old gmc general from a tractor to a dump....to do it right was a long drawn out deal....it turned out pretty nice but was a lot of work ..took the bunk off stripped fram down had new rails bent to slide inside old frame ..we doubled it up under the cab...had to shorten the xmembers luckily this truck already had hendrickson but had drill into new inner frame...lots of drilling!! removed one fuel tank added wetline tank,reworked smokestack..added leafs in front from 12k to make 18k fronts...new floaters on fronts put a new 15 1/2 steel galion dump...made a really nice truck but what a lot of work ...it could have been cobbled with way less work but then in a year or two of offroad dirt work it would have broke into...anyjob worth doing is a job worth doing right!...( this was back in late 80/early 90 and truck was still running last year..)
    ampm wayne and rogueunh Thank this.
  6. rogueunh
    1,082
    22,200
    Jan 4, 2011
    Good points guys and thanks.
    I guess selling the tractor and buying a dump makes more sense.
  7. Big John
    Big John Road Train Member
    2,022
    1,521
    Oct 7, 2006
    Oklahoma
    No need to buy a dump truck if you like your truck. A lot of dump trucks running around are ex-road trucks. See what it would cost to convert yours it may be cheaper or it may be cheaper to trade. Talk to someone that builds dump trucks. You can double frame yours from the cab back and heavier front axles are not hard to find. Your gearing should not be an issue and we have oil field bobtail tank trucks running around with 40k rear axles.
    http://www.truckpaper.com/drilldown/manufacturers.aspx?ETID=1&catid=217&bcatid=27
  8. rogueunh
    1,082
    22,200
    Jan 4, 2011
    I do like the truck and it's running good.
    I will look into it, see how much it would take.
    Used dumps aren't exactly cheap......
  9. 1988pete379
    1988pete379 Light Load Member
    193
    75
    Feb 28, 2009
    North East TX
    We did this one and this is how it turned out . Started out with Cummins Big Cam IV 400 , RT 15509 trans, and Rockwell SQ100 3:55 .
    We have done a Cummins ReCon Engine traded the 9 spd for a RT0 15 spd .also pulled the Rockwall rears out and rolled a set of Eaton DS 402 3:90's . When the frt rear end went south on us we pulled both carriers and went back with a 4:11 ratio
    Latest thing we did was Get rid of the lo flo cooling system and went back to a high flow .
  10. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    I've built 2. The first one I had I drove 4 8 years. It all depends on what exactly you are going to be doing with it. I run a pusher and that compensates for the 12k front axle most of the time but not all the time. On both trucks I purchased 18k rated front springs as well. There is also lots of suspensions to avoid if you off road. There are only a handfull of drivers I would put in a conversion.
  11. gravelhauler
    gravelhauler Medium Load Member
    630
    412
    Oct 20, 2011
    Lake Charles, La
    Most trucks with a 48" sleeper will take a 15 to 16 ft bed easily. I've helped convert several road trucks into dumps. I've driven a few of them also. I drove one with a 9spd OD and 3:55 rears. You had to be careful when off-road but it got the job done.
