Tractor Protection Valves
Discussion in 'Trucks [ Eighteen Wheelers ]' started by metric adjustable, Sep 5, 2011.
  1. metric adjustable
    metric adjustable Light Load Member
    140
    75
    Dec 16, 2010
    dunno; gps is down
    Just curious; I have a tractor protection valve on my truck that seems to act contrary to what i was taught. I understood that when the emergency line 'broke away' or was disconnected, the tractor protection valve would almost instantly cut off air flow from both service and emergency line ports to keep the tractor air supply from exhausting. am i wrong?
    The valve on my freightliner allows air to drop down to below 60 psi before shutting off flow. It has been replaced before, and the previous valves did exactly the same. The protection valve on my truck has five lines; two input for service and emergency, two output for same, and a green (secondary?) air line coming to the bottom of the valve. On an air system trainer the company has, a four port valve is used; two input, two output. breaking the emergency gladhand results in an instantaneous cut off of air.
    why the difference?
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Ok, I think you are getting the tractor protection valve and the dash park brake valve mixed up. The dash park brake valve is not a tractor protection valve. The tractor protection valve does close instantly when there is a break away. This valve will prevent service air brake pressure from going out the valve. With the trailer park brake button still pushed in, air will continue to rush through your dash valve until the drop in pressure is between 65 and 35 psi. The reason the pressure "kick out" of the buttons is so low because during an actual breakaway the trailer emergency system would normally be charged to 120 psi or so then it would drop very rapidly when the line is opened. You really do not have too much pressure at an open line, just alot of flow, so that is why the button will pop out at such a low pressure. When driving and you lost your trailer the button would pop out well before your truck system got down to under 60 psi.
    [ame]http://www.youtube.com/watch?v=-1vA1EnNJZ4[/ame]
    123456 and metric adjustable Thank this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    usually trailers are with emergency valves and when you disconnect supply line (red gald hand), ore if you pull out trailer supply button trailer park brakes are actuated with trailer emergency valve.
    valves installed on new trucks are to prevent dumping air from trucktor if supply line is broken.
  5. poniikyanion
    poniikyanion Light Load Member
    69
    14
    Nov 23, 2009
    Newark, NJ
    Tractor protection valve is designed to shut off the air flow from the blue line (service) when the there is no air pressure in the red supply line (emergency), when your dash red supply button is up.
    So when you press on the foot brake the blue line will have no air flow going out the blue line. It is not designed to stop air lost of emergency line when there is a break away. That will be the job of your dash valve.
  6. metric adjustable
    140
    75
    Dec 16, 2010
    dunno; gps is down
    I'm speaking of the valve similar to the one shown in the youTube video above (nice, btw; always wanted to see inside one of those). Mine is similar, except with another port opposite the spring end, into which feeds a green air line. If i understand the posts above, the TP valve doesn't cut off the emergency feed, but only kills the brake service line?
  7. poniikyanion
    69
    14
    Nov 23, 2009
    Newark, NJ
    This is exactly what I meant.
    BTW, the 1 extra smaller port in a 5 port valve is usually a connection for your foot brake pressure guage in the dash and the stop light switch sensor.
