Tractor parking brake doesn't hold 44K load on steep on-ramp
Discussion in 'Experienced Truckers' Advice' started by JC1971, Mar 5, 2020.
  1. JC1971
    JC1971 Road Train Member
    2,607
    9,293
    Jul 29, 2013
    L.A.
    Pulled over on a steep on-ramp, set the brake, and the truck started rolling. Good thing I didn't go straight to the sleeper to grab something. What causes this? Just weak spring pressure or should you set trailer brake, also? This is the first time I've ever seen this.
  3. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Brakes are out of adjustment. Would be the first thing to check and is usually the problem.
    Should always set the trailer brakes too. And if they don't hold. See above comment.
    Also, angle the steering so if the truck should roll. It's steered in a safe direction. Preferably against a curb or something so that the truck has less chance of rolling away. If a curb or something is available.
  4. AModelCat
    154,214
    Bet most of your park springs are busted. If it held with your foot on the pedal but not with the park brake that'd be my first suspect.
    ChevyCam, Dino soar, magoo68 and 8 others Thank this.
  5. Numb
    Numb Crusty Curmudgeon
    3,934
    8,733
    Jan 30, 2012
    Charlotte, N.Carolina
    you have to ask,why?
    ChevyCam, lilpete42 and clausland Thank this.
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Next time look out to see if only one tire is sliding on ice , most trucks have emg. brake one drive axle, all trailers have emg. brakes on both axles so if you dont set trailer emg. brakes you are in trouble?
    Dino soar and Rideandrepair Thank this.
  7. JonJon78
    JonJon78 Road Train Member
    7,039
    37,536
    Jul 1, 2018
    Always set the trailer brakes when on a hill or anytime you park the truck?
    ChevyCam, Coffey and Rideandrepair Thank this.
  8. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    That’s too much weight for the brakes on the tractor to hold on a slope. I’d get them checked too but I’ll bet it’s mostly the weight and the slope causing you to slide.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Broken spring in brake pot. Some trucks only have parking brakes on one drive axle. So you may have only one brake trying to hold it in place.
    ChevyCam, Dino soar, Bean Jr. and 2 others Thank this.
  10. snowwy
    20,525
    13,261
    Jul 6, 2009
    The thread is talking about an incline.
    Relying on tractor brakes only could cost you your job. As the op is finding out. But hey. It's a good way to tell the brakes are out of adjustment.
    JC1971 and Rideandrepair Thank this.
  11. JonJon78
    7,039
    37,536
    Jul 1, 2018
    You said always so I was looking for your definition of always
    88 Alpha and Rideandrepair Thank this.
