Tractor empty weights?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Floyd, May 25, 2013.
  1. Floyd
    Floyd Light Load Member
    163
    25
    Jun 1, 2010
    Central Maine
    I'm trying to determine approximately what weight a modern, class 8 tractor will weigh.
    A lot of variables here, but here are some spec's.
    Peterbilt 379 or Kenworth w900/t800
    60"ish bunk
    12 front
    40 rears
    air ride
    single frame
    c-15
    13 or 18 spd
    2 line wet system w/50 gallons tank capacity
    Again, just some basic specs. Anybody have similarly spec'd trucks that know how much they weigh?
    Thanks.
    Road Killer Thanks this.
  3. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    I'd say 20-22K
    Floyd Thanks this.
  4. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    2002 t800
    Detroit
    13 speed
    22.5 low profile on aluminum wheels
    120 gallon tanks
    Side exhaust
    Two toolboxes full of junk
    Headache rack with about 200 feet of chain
    60" sleeper
    236" wb
    12/40 axles
    Right at 20k full of fuel with me in it. Door tag says 16,834. Do a search on truckpaper a lot of times they take pictures of the weight tag.
    Road Killer and Floyd Thank this.
  5. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    my 2002 T600, C15, 18sp all alum wheels, centrifuse drums (light), twin 150 tanks, 72" sleeper was 20,500# half full of fuel. KWs are heavy like they're full of dead bodies.
    my 2013 389 is 17,200 full of fuel with the same drivetrain and a 36" bunk
    Floyd Thanks this.
  6. Floyd
    163
    25
    Jun 1, 2010
    Central Maine
    Thanks for the replies so far!
  7. Floyd
    163
    25
    Jun 1, 2010
    Central Maine
    Interesting. I wonder if this is typical in that the Pete's tend to be lighter than a similarly spec'd KW.
    Thank you for the reply.
  8. Floyd
    163
    25
    Jun 1, 2010
    Central Maine
    I'm trying to spec a truck to go along with a tri-axle 180bbl aluminum vac. tank for hauling in the northeast. I'm drawn to the Pete's, but i still have to keep a hold on what is efficient in order to maximize my payload and of course fuel efficiency.
    I currently own a small fleet of 3 tractors 6 wheelers and a tri-axle. These trucks are all designated for local farm use hauling feed from the field to the farm and the tractors mostly pull tankers in the 8500 gallon range for hauling manure from the farm to the fields. Local meaning our average field distance from the farm is in the 5 mile range.
    This will be my first truck purchased for long haul operations. Propobly will be used but possibly new lease. If i go used i need something in the 75,000$ range.
    Thanks again in advance for any advice.
  9. Bigfoot62
    Bigfoot62 Light Load Member
    92
    29
    Oct 29, 2011
    Louisiana
    ^ What he said.
    My T800 is a little lighter (19K + change), but it's a 9sp and a 10.3L CAT. 230" w/b, 60" sleeper, 2-line wet kit with 50 gallon hydraulic tank.
    The T6's and T8's are a little lighter than the W9's, but not much. The Pete's usually run a bit lighter than KW's, but again, not by much. It all depends on how they're spec'd. (even tire size will affect weight)
    BTW, for $75k, you should be able to find a really nice rig.
  10. BullDoggin
    183
    56
    Jan 27, 2013
    If you're going for light weight... stay the hell away from Kenworth. This also goes if you're looking to buy a truck from a company that will give you good service and parts availability down the road after the sale. I will NEVER own another KW. Kenworths are pretty... and that's about it.
    LSL mack Thanks this.
  11. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I have to add mine was 18,900 full of fuel.before I added the rack, boxes, and gear.
    I lost 2400 lbs from my 99 Volvo 770. It had a lighter engine too, but virtually the same specs but huge sleeper. 232" wb, Volvo engine, 13 spd, 120 gallon tanks. That thing was a monster.
