Tractor brake chamber is hanging. What part do I need?
Discussion in 'Questions From New Drivers' started by xzmpt, Aug 3, 2024.
  1. xzmpt
    xzmpt Light Load Member
    74
    67
    Nov 22, 2022
    IMG_3595.jpeg Did my pre trip and noticed one of my brake chambers was hanging lower than the other. The first pic from above where you can see silver metal is the one that’s hanging. Looks as if something may be broken off. The second pic from the side is the other normal brake chamber. What’s missing?
  3. Espressolane
    16,975
    102,336
    The mounting bracket for the chamber is broken Do not drive this if at all possible. The brake is not working for that wheel/axle. From the condition of the push rod, it looks like this has been broken for a while.
    This is an OOS condition.
    tscottme, beastr123, ducnut and 2 others Thank this.
  4. Ridgeline
    22,103
    113,210
    call road service or have it towed and get it fixed RIGHT.
    TX2Day Thanks this.
  5. xzmpt
    74
    67
    Nov 22, 2022
    I’m abou 30 miles from
    Called road service and they told me to deliver the load. I’m 30 miles from the customer and my appointment is tomorrow at 9 am. The TA I’m at said they wouldn’t be able to get the part and fix it until Tuesday. Tight spot.
    77fib77 Thanks this.
  6. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    It's gonna need a s cam tube. Not a hard fix. Me personally, I would deliver. As long as your other brakes are good, i think you're legal under the 80% rule???? But you need to secure it.
    I've broken 2 over the last 2 years and drove them home, but my truck too
    blairandgretchen, 201, 77fib77 and 3 others Thank this.
  7. Espressolane
    16,975
    102,336
    Did you get the drive and deliver in writing?
    guess it’s your call.
    The chamber mount is broken. The only thing keeping it on the truck is the air lines and the push rod. I am not one to mess with brake issues. Just not worth the hassle.
    tscottme and xzmpt Thank this.
  8. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    just did one 2 weeks ago, had to change the spider to, put a strap around it so the shoes weren’t dragging and drove her home, not wasting money on a road call or tow when I can do it myself, and know it was done right
    Oxbow and Big Road Skateboard Thank this.
  9. Ridgeline
    22,103
    113,210
    Yeah you can, but the OP was asking a question about what needs to be done which tells us that he should not do the work himself.
    Wargames Thanks this.
  10. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,318
    2,216
    Jan 7, 2023
    Yeah, spring canisters are NOT a job for the untrained...
