Tractor ABS Light
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Sep 15, 2012.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,737
    601
    Feb 21, 2010
    Miami
    Hi,i have a question i have a Columbia 07 ,my tractor abs light is on,i was in my repairshop,the mechanic was checking my problem and he tell me ,he dont can find the problem i have to bring the truck to the freightlinerdealer to find the problem,he tell me the cable from abs is ok,somebody have any idea what is wrong with my abs
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    any abs code throms MID 136 fault codes
  4. gerardo1961
    1,737
    601
    Feb 21, 2010
    Miami
    I dont see the fault codes only the abs light is on
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    When the ABS light is on that is indicating that there is currently an Active ABS system fault. It could be anything, anywhere. All or part of your ABS will be disabled, but you will have normal regular air brakes. There is absolutely no way of telling what is wrong with out getting a fault code. Some trucks have ways to initiate ABS fault flash codes where the ecu will flash the ABS light in a sequence and you can count the number of flashes and get the code number. Check your owners manual, as I am not familiar with your truck. Some trucks have an actual "ABS DIAGNOSTICS" switch under the dash somewhere that will start the sequence. If you can't find anything, you are looking at taking the truck to the reputable dealer. Since you drive a Freightliner I highly recommend you go to a Freightliner dealer where they know your truck's wiring the best and have all the wiring and diagnostic information that pertains to your truck! Good Luck!
