Tracking down new issues - air bubbles in fuel tank etc
Discussion in 'Volvo Forum' started by southbaydad, Dec 18, 2019.
  1. southbaydad
    southbaydad Light Load Member
    281
    34
    Dec 10, 2009
    Arizona
    I emailed you Nas but thought I wouldput it in a thread for others also
    New issues are as follows:
    After engine is off overnight or several hours it takes about 10-15 seconds of cranking to fire
    Doesn’t run rough. Power seems to be good
    When it’s first started in the morning, the burn rate is around 0.8 gph BUT after a few minutes of idling it goes up to 1.7 or 1.8
    ——— LEFT side fuel tank HAS bubbles from line
    ——— RIGHT side tank has NO bubbles
    Fuel mileage all of the sudden really bad. Jacksonville to El Paso 3 fuel stops 5.7 then 5.4 currently showing 5.2 —- use to be in the 7’s
    Deadheading use to get 9 to 10mpg. Now really hard get 8mpg
    Oil level not rising in crankcase
    First thought was air leak somewhere ——Nasriza I think remember you telling me get a new clamp?. But had so much going on in my head don’t recall what and why
    The new turbo seems great but the Turbo boost is very very reactive Very little foot pedal pressure and it’s at 20 pounds plus maybe it’s normal and I was just use to my old 900k miles turbo
    Can a boost leak somewhere in the system cause this super touchy turbo to create more boost than might be needed?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    i am not familiar with Volvo engines but bubbles in fuel tank mean you need new o rings for injectors and injector cups for detroits...
    southbaydad and Newto Trucking Thank this.
  4. southbaydad
    281
    34
    Dec 10, 2009
    Arizona
    Yes you might be right. All I have read though seems to only talk about bubbles in the Right side tank
    mhyn Thanks this.
  5. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    If you want to, try bumping up your idle speed to a 1000rpm and look again in both tanks. There’s just one return fuel hose coming from fuel filter housing and going back to fuel tanks. So it really don’t make a difference left or right tank.
    southbaydad Thanks this.
  6. southbaydad
    281
    34
    Dec 10, 2009
    Arizona
    Ok I can try that
  7. Bold Group
    Bold Group Bobtail Member
    22
    19
    Apr 23, 2019
    Please keep us posted as we have the same issue. Though we don't have dropped mpg and we changed injectors and cups and turbo 7 months ago at Volvo dealer.
  8. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Need new cups most likely. Need to go to a dealership or a good shop for an air test to confirm, highly unlikely that it has anything to do with the turbo. Cost to replace cups etc will vary but approx 4500 to 6000 usd depending(and I repeat this is an estimate prices will vary). If you go to a volvo dealership you will get a one year warranty on cups and labor. At a shop just parts warranty. Your call on it. Crappy christmas present but that is the way it goes. Good luck
  9. Bold Group
    22
    19
    Apr 23, 2019
    If there are bubbles in both tanks does it mean fuel filter housing needs to be replaced?
  10. Newto Trucking
    359
    225
    Dec 26, 2013
    NE Illinois
    No you don’t need to replace fuel filter housing. You will be better off to test for air in fuel system just like @Rob100100 suggests. All Volvo and Mack dealers would be able to do a test. There’s basic test and also advanced test. You will need to do advanced if you want fuel filter housing checked out.
    Bold Group Thanks this.
  11. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    the volvo I just got ride of had the returns in the top front of tank if its like that your going to get bubbles when the fuel drops down in the lower fuel
