Hello - I have 22.5 Toyo steer tires that are getting very strange wear. Almost as if someone took a knife and sliced off random chunks!! It seems to be more pronounced since an alignment 2 months ago. Any ideas? Someone at a shop suggested King Pin. See pictures.![]()
Toyo Steer Tires strange wear - see pics
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DallasTrucker, Oct 2, 2013.
Page 1 of 4
Well, that looks like a Toyo M147. I used to run those steer tires and every single set did the exact same as those in the picture. 1st time I did the new shocks, new kingpins, new shackle/hanger/pins & bushings deal. New Toyos did the same thing right @ around 65k miles. I would even rotate them every 20k miles from driver side to passenger side. I'd take them and run them on the trailer after the indented spots became more pronounced(80-90k miles). I switched over to General S371,Cont HSL2, or Cont HSR2 and problem is gone. I have a Pete 379. I also run them @ 100psi with centrmatics. Do get the suspension checked no doubt.
puncher Thanks this. -
Thanks Everlac, you are right M147's. The wear is so strange it's hard to see how an alignment or shocks would cause those random patches. I've had them for 110K miles and the tread depth is still good. About how many miles should these or average ones go when bought brand new?
I agree I would check suspension but doubt that is cause although you may prevent a future wear issue. I have had similar tire wear and as posted earlier the only cure was different brand tires which just happen to be the General S371 and they are wearing even like they should.
DallasTrucker and EverLuc Thank this. -
That said, if I need buy new tires (except michelin) I would look closely to OHTSU. Very, very good looking tire.DallasTrucker and EverLuc Thank this. -
I used them close to 220K. 100K or close on the steer then I'd move them to the trailer and wear them down some more. When the weird spots lost tread, I would regroove those areas. Usually by the when you have worn them down enough to require complete regroove of the tire, those flat spots are down to the wires. If the spots are ridiculously flat or recessed, you will feel it in the cab regardless of where it is mounted. Chunk it or use it as a spare as you will most likely ruin the tire it is paired with, cause a wheel seal to leak and loosen up any parts being shaken loose. Run a different brand tire after you check the suspension. Something with a closed shoulder. That Toyo has that lip that has a little give to it and sometimes tears.
Here are the things they recommended I do but from what i'm hearing, I'll be wasting money. They do have 110K+ miles and installed new July last year by the same shop. This time they recommend Sumitomo. I've had my shocks replaced in Nov last year and alignment done this July. The question now should I just replace the tires and keep going as the alignment was done recently?
On my old bill from tire shop there is a note that re-aligment should be made every 30k miles (!?). I personally do it once a year (100k).
Oh yes, I did lube 5th wheel. On one trailer I have that slick disc that mounts around the kingpin. I also have those tru align sleeves that center up the wheel on the studs. Steer axle only. Had truck and trailer aligned. I did go down the cheaper brand route i.e primewell, linglong one time for the trailer only because I got them for $260 each if that @ some one bay tire shop. They wore down to the steel belts on one side only. Too funny. Otsu does look good, but the Generals, Contis and Bridgestone look very good with tire shine yup.
Hurricane69 and deming807 Thank this. -
Page 1 of 4
