Tow Strap size ???
Discussion in 'Experienced Truckers' Advice' started by Capt Dan, Nov 29, 2012.
  1. Capt Dan
    Capt Dan Bobtail Member
    17
    4
    Jun 21, 2011
    East Central IL
    Hello, I am looking to purchase a nylon tow/tug strap to put in the truck this winter. What weight limit should I purchase if my main use would be to pull start other big trucks, or me if the battery fails or pull a bob tail rig out of a minor slick spot. Not wanting something designed to pull big trucks out of big ditches, just a size and weight limit for light duty as described above.
    Thanks, Capt Dan..
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    you want a chain. 3/8 links or bigger. with hooks. preferably 2 chains.
    you'll also want a big hook mounted to the frame. sticking out through the bumper.
    straps won't work. and most trucks won't have hooks.
    you also need to think about the rear end. it's not capable of pulling 2 semis full loaded. that's 160,000 pounds plus the force needed to pull.
    i used to drive a dump truck. with a trailer i weighed upwards of 100,000 pounds. when loaded. come winter time. you get stuck A LOT.
    don't know what you plan on pulling or you being pulled but the weight is pretty extreme. i don't think most semi's are rigged up for being pulled. you'll tear them apart. or your own rig. best off leaving the job for tow trucks.
    i pull flatbed so i have chains. i've helped cars but won't attempt semi's. the one time i did. i shattered the rear end housing. and that guy only needed to be pulled 4 feet before he had traction to move his rig.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I don't know what to tell you in regards to tow strap size but its just fine to do what you're thinking of doing. Its like anything you have to use some common sense and not get crazy.
    Only way you're going to shatter your equipment is to not use common sense and have a heavy right foot.
  5. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    A good chain will be fine. My bumper is bent out quite a bit from one too.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,521
    17,999
    Nov 1, 2010
    Burnsville, MN
    Sounds like you want a minimum range.
    Why not go for the gusto and get the best?
    Face it, pulling any big rig out is not 'light duty'.
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    do not use a chain, if a chain breaks it will do far more damage, also a proper tow strap will have some stretch witch increases pulling power without increasing load, if that makes any sense sorta like a sling shot. also if your pulling someone else do not spin your tires, first try to ease the slack out of the strap and give a light pull if that doesn't work back up about 2 feet low gear try again. hit it lightly to snatch the vehicle, remember the weight of your truck being pull to a stop is a tremendous amount of force so it does not take much of a bump, if it doesn't work with a light bump unhook and call a wrecker.
    this is the type of strap that i recommend
    http://www.northerntool.com/shop/tools/product_200232524_200232524
    do not get a rope that has attached hooked, as these hooks could potentially become deadly projectiles.
    use clevis d-shackles for your attachment. hooked threw the i of the attachment point every semi iv ever dealt with has had proper recovery points on the front, some of them are a removable receiver style others are pull pins located behind the license plate a few other styles as well make sure that you are hooked to a proper place. and that your d ring is securely attached to the attachment point do not pull your rope threw or around your attachment point and then hooked back to its self. this is both to maintain the integrity of your rope but also to keep your d-ring from becoming a deadly projectile if the strap were to break. (the same reason for not getting a strap with attached hooks or using chain) also do not use open faced hooks for the same reason mentioned above.
    make sure your rope is appropriately sized. min 100k lb load rating if you are even going to think of hooking it to a semi
    aber and MJ1657 Thank this.
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    if your in a bind and choose to use a chain hang a blanket over the chain before trying to pull, if the chain were to break it will absorb the shock and make the chain fall to the ground rather than becoming a projectile.
    anyone that has ever seen a chain or cable pulled under a 80k lb load break knows why i keep bringing this fact up. i have seen a chain leave dents in 1/2 inch thick steal before.
    check your local tractor/farm supply stores for your best deals on recovery straps. normally $250-$400 will get you a appropriate tow strap. min 100k lb load rating
  9. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Never use a chain, cable (wire rope, yes). Chains kill people, they like to snap. We pull each other alot in our industry, just because of the nature of the bulk loads and bottom, chains are the quickest way to the er room or morgue.
    Straps and cables should be rated for at least 4 times of the load weight (minimum 100K). Straps are the best way to go and you will not regret the investment.
  10. Capt Dan
    17
    4
    Jun 21, 2011
    East Central IL
    Thanks for the replies, however I don't understand why I would need a 100K lb tug strap to bump start at bobtail tractor that will only weigh 20,000 lbs or there abouts. Also if I am only getting a bobtail tractor off of a slick spot in the parking lot, why would I need a 100K LB tug strap. Like stated in my original post, I will not be pulling anything out of a ditch, or pulling anything attached to a trailer, strictly light duty (tractor to tractor only). I have seen several that are 3" or 4" with a 27000 or 30000 lb range, would that be adequate for my above listed needs.
    Thanks again for your help,
    Capt Dan..
    MJ1657 Thanks this.
  11. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Since you obviouslyalready know better than all experience here, why would you ask. this is not really a question.
