Whats a good sized tow chain to say yank a loaded truck out if he’s stuck in a snowed/iced in spot? I aint trying to pull anyone out of a ditch or anything crazy. Just say at a truck stop where 20 feet away is dry/cleared pavement I could throw a chain around my trailer dot bar and yank someone out by there tow hook?
Tow chain/ Tug chain for assisting other drivers?
Discussion in 'Experienced Truckers' Advice' started by 4wayflashers, Dec 23, 2022.
Page 1 of 5
snowman1980, RubyEagle and 4wayflashers Thank this.
I’d use a strap
and some Clevis hooks or something
Several companies make straps designed to stretch , specifically for unsticking vehicles , so there isn’t a shock load to whatever you’ve hooked it to -
Yeah a strap would probably be best. I carry a few large coffee cans of gravel, sand, rock salt. Now I’m thinking about it i should probably only carry the pea gravel but its what i got. I also carry a long handle steel transfer shovel for if it gets bad.
One time at a company yard in Joliet everyone was trying to hook a trailer and instantly Got stuck under there newly hooked trailer one after another, myself included. Using a claw hammer I chipped away at the inch of ice under my drives. Finally after making little progress I tried pouring -30 window washer fluid on the spots I was trying to clear. It loosened the ice up to wear the claw hammer was breaking up large chunks instead of just chips. I was able to get a bit of momentum then and got myself out but it wasn’t much fun.
A 2 million miler was about to call for a tug when I suggested he try the washer fluid. He laughed and I reminded him the megas consider getting stuck on ice a preventable. He was all ‘not me, I’m a 2 million miler’ but I saw him pulling a jug of washer fluid out of his side box as I pulled toward the guard shack lol.
Mostly I’d hate to even hear what the wait time for a wrecker would be on a morning after an ice storm.
(Before anyone says to carry cat litter. Why would you carry cat litter when you can get pea gravel or sand just as easily? I’ll never understand that lol) -
Worx great...double up if necessary
I use it to pull heavy pallets to back if wagon also if no dockAttached Files:
tscottme and gentleroger Thank this. -
A nice kit like this is $70. I don’t think you’d need more capacity than this, if you don’t get crazy.
RubyEagle, 4wayflashers, gentleroger and 1 other person Thank this. -
Well, hold on, how stuck and how heavy. I've seen chains break and a strap won't cut it, those are for 4 wheelers, not 80K. You may even bend the under ride bar, explain THAT to the boss. A simple tug is about all you can do. If they are stuck to the hubs, not much short of a wrecker, or tank retriever will work.
4wayflashers Thanks this. -
I pulled a white Volvo out with a 3/8 chain... but he was just barely stuck on a patch of ice and spinning the tires.
RubyEagle, Siinman, JolliRoger and 4 others Thank this. -
4wayflashers, tscottme, gentleroger and 2 others Thank this.
A strap will work great. Just remember if your using your DOT bumper, be careful when "yanking" cuz DOT bumpers are not meant for that and you might end up yanking one off or bending it good.
PaulMinternational, D.Tibbitt, 4wayflashers and 2 others Thank this.
Page 1 of 5
