Do you guys know how many gallons of fuel a stock 2015 freightliner cascadia holds?
There are 2 tanks, 1 on each side.
I'm thinking 200 total gallons (100 in each tank) but not 100℅ sure.
My company gave me a 2015 freightliner cascadia and just wondering exactly how much fuel it holds.
Total gallons 2015 freightliner cascadia?
Discussion in 'Questions From New Drivers' started by Jdm5jdm5, Feb 15, 2017.
It should say on the tank at the fuel cap it should be stamped in to the aluminum tank
Getsinyourblood and Jdm5jdm5 Thank this. -
Yes you will need to check tanks but if it's a otr truck 2x100 gallon tanks is most common... Would depend on how they ordered it
Jdm5jdm5 Thanks this. -
I can tell you that a 2016 Cascadia will truck you down the road 170 gallons before it stalls out on Arkansas US-67.
Truth.Trokera65, bottomdumpin, Jdm5jdm5 and 1 other person Thank this. -
We get 2 120s, which are good for maybe 215 out, I have run it farther but it may start a little hard.
My 2015 is fairly stock. Has 2x100 tanks. The total draw is only 165 gallons though. I once (only once) ran out of fuel just as I pulled into a fuel island, set the brakes and was writing down my mileage. Anyways it took 167 gallons because I kinda topped off the tanks. True story.
Typically, a 100 gallon tank will hold 95 gallons. That of course is filling til all air is out and fuel is at top of filler cap. 95% of tank size is what most tanks hold. That info as well as tank size is usually found stamped into tank around fuel cap.
Now yes, I've seen trucks with square tanks that do have the fill at the top most location, but those are rare in my experience.KillingTime and Jdm5jdm5 Thank this.
