Torque wrench
Discussion in 'Ask An Owner Operator' started by mitmaks, Feb 28, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,541
    2,064
    May 16, 2014
    Which torque wrench you guys have to torque those lug nuts to 475? ft/lb
    Im looking at buying one so I can do some work on truck myself. I see they cost upwards of $400 for one.
  3. rollin coal
    rollin coal Road Train Member
    13,078
    25,828
    Mar 29, 2008
    TN
    I use a CDI 6004MFRMH 3/4" drive.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
  5. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    Whichever you get, be sure to have calibrated. Usually you can find a deal on eBay. Got mine for 75$, then maybe 15$ for tubing and clamps. Worth it on $ you save doing tires yourself.
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    3/4 rechet wrench with a cheater bar.
    Even when they come out on road and torque your wheels ( with a high dollar torque wrench )they ask you to check them after the first 100 miles in writing.
    What does that tell you?
  7. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    That is called a legal CYA. They require the same when done in a tire shop. Just had my steers rotated in a TA, Had to sign the paper saying as much.
    Just in case there is something between the wheels that comes out and lets your nuts loosen.
    Also using a torque wrench should prevent the stretching of the studs.
    Bean Jr. Thanks this.
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i really need to buy a big tq wrench for lug nuts but its really the only thing i need one that big for. what i do is i calculated using my body weight how far out i need to be on a breaker bar hang my weight on it then i have a breaker bar with that distance marked on it.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,692
    Mar 30, 2014
    I remember reading a thread. The poster owned the truck, and the driver had some obsession with torquing the lug nuts everyday. They were close to impossible to get off.
    AModelCat Thanks this.
  10. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    @Bean Jr.
    That driver prolly had nightmares about his wheels coming off.
    I have a similar phobia...so I usually ask someone else to double check the lug nuts
  11. AModelCat
    154,214
