Torque specs for MX-13
Discussion in 'Peterbilt Forum' started by FdEF, Oct 5, 2018.
  1. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    We are putting all the components back on our mx 13 before we stab it back in but are having a hell of a time finding torque specs. I know i can spend six hundred on a service manual but isn't there a website or something? Mainly looking for bell housing, motor mounts, oil pan, clutch, flywheel, etc
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Your engine serial #?
    FdEF and Oxbow Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    When all else fails, you can never go wrong with universal bolt torque by thread size, pitch size and bolt hardness. Only time you really need to defer from this would be everything inside the engine, cylinder head, top end and bottom end are torque turn specs or tty.
    Cat service info is the most frustrating for me to find torque specs. If I looked up every bolt spec I would die before I got a rebuild done.
    Engine fly housing to block - 82 ft lbs
    Flywheel- 60, 192 ft lbs plus 2 flats
    kylefitzy and FdEF Thank this.
  5. FdEF
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Y064991
  6. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Here are most of torques you asked on engine. Paccar changes clutch and engine to trans fastener torque all the time! Clutch I usually go with new lock washers and 45 ft/lb on M10 bolts. Engine to trans I use blue threadlocker and 50 ft/lb on M10 bolts. KW has service manual for the new style trelleborg motor mounts so I attached that also.
    P.S. Yes, flywheel bolts spec is correct and is very tight. I replace the bolts with new.
    FdEF, Cat sdp and pushbroom Thank this.
  7. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Yeah nobody believes the torque spec on the flywheel.
    Yes, its tight
    spsauerland Thanks this.
  8. Trnpke
    Trnpke Bobtail Member
    Thanks for this!
  9. Dylan Reeves
    Dylan Reeves Bobtail Member
    Does anyone know the torque specs on the flywheel bolts on a 379 peterbilt
  10. Diesel Dave
    8,520
    23,410
    Jan 20, 2010
    Hesperia, Ca.
    Need more 411, year, type of engine is you wants replies
  11. Dylan Reeves
    2004 Model ISX 475
