Ok,
Now compaired to spending $$$ on impacts ( Have 1" ) and a bigger compressor, not to mention non of these would help on the road. I've been looking at a Torque multiplier lug wrench for on the road emergency and when I don't feel like dragging all the tools out. Have you guys/gals used this tool. Would like some recommendations.![]()
Torque multiplier lug nut wrench
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Waterman1000, Jul 4, 2010.
Page 1 of 4
Don't think I've seen one of these. Although I already have all the other stuff this might be something good to have.
I never have bought one, but always wanted to. Their expensive. At 700 ftlbs which is what most of the truckstop torque them down to, I had to use a 3/4 breaker bar and 7' cheater bar, granted I'm only 165lbs. Even then I once broke a 3/4 cheater bar before loosening up the lugnut. I ended up buying a higher quality S&K 3/4" breaker bar and it's held up great. If you use the breaker bar and cheater bar combo, you'll want a tall jack stand in order to do the drives and trailer wheels, otherwise you'll end up just slipping off the lug nut. I use the jack stand to support the extension between the breaker bar and socket. I think those geared down rachets are over $600 and my breaker bar and jack stand are about $100 so that's why I went that route. I just straped down the cheater bar across the catwalk with all my other stuff. If money is no object I would buy the geared down ratchet but for me money was a deciding factor. That's all the info I can help out with, good luck.
I have and use the X12 torque multiplier, came with the coach. Works great without the need for a support of the extension & cheater bar setup. Pricey at nearly $700, I doubt I would have sprung for it, but I like it just the same.
TIA X12 -
We have been using a 3/4" impact to take our semi lug nuts off until my dad saw a 1/2" super strength impact that has 1200 lb/ft of torque for $199 at Northern Tool. We tried it the other day and it was just as strong if not a tad bit stronger than our 3/4" impact. And it operated on the smaller hose too!
wheels should be torqued to a 450 ft lb max ! stud failure and potentially fatal wheel loss could result !!!!!!!!!!!!!!!!!!
bbechtel16 and JohnP3 Thank this. -
450-500 ft/lbs on hub piloted...
http://www.todaystrucking.com/images/WebbWheelTorquebrochure.pdfLes2 Thanks this. -
I know i used to use a 1/2" impact on mine. I've seen 3/4" guns snap the studs off.
Page 1 of 4
