I decided to move my antenna on my pick up truck from the rear quarter panel by the tailgate to the center of toolbox behind the cab, looks better, slightly higher and farther from damage and theft. But for the life of me I can't get the thing grounded. My SWR is 3 or higher using external meter and Galaxy 959. I grounded the mount to the frame, the toolbox to the frame and to the truck bed. And nothin, no change. Any ideas? I'm sure someone has a good set up with it on the toolbox. Or just move the antenna somewhere else?
I was also using plain insulated copper wire to do the grounding. Is that my problem? Do the braided grounding straps work that much different? I'm fairly new to this and eager to learn
Thanks for any advice
Toolbox antenna
Discussion in 'CB Radio Forum' started by johnethan77, Feb 26, 2016.
That is typical of using the toolbox to mount an antenna. I've tried it on several different trucks and never could get it satisfactory. First off, it's aluminum. In answer to your question, you don't ground, you bond. Yes, braided straps are best. Large gauge, fine wire like they use in big stereo installs seems to work well also. Second, you need more than one strap. Bond all four corners. Be sure you grind attachment points down to bare metal. The last truck I tried this on I found the bed wasn't bonded well either because even mounting an antenna to the bed did not solve the high SWR problem. I read where someone had to bond all four corners of their bed to get good results. I gave up and mounted it on the left front fender with excellent results and finally just drilled a hole in the roof and mounted in the best possible place on a vehicle. And, I am planning to drill a hole in my 2015 GMC pick up as well. It won't hurt the value and If I'm gonna put a radio in it, I want it to work as well as possible, within reason,.... as in I won't be mounting a 102" whip up there.
Thank you I appreciate the info. Im going to go get some braided straps this morning and try. I was using very thick solid copper wire lol. And it worked great when was on bed so maybe if I get it bonded correctly it will work. And a hole in your 2015? I'm scared to do that to my 08 lol
I made a bracket for the antenna and move the grounding point back to the body, which made a huge difference because I could put an additional ground going to the base of the antenna.
My toolbox is bed lined and I forgot to scrape it off around the mount lol -
I made the bracket that went above the tool box by a couple inches so I could open it, it had one lid that you lifted. I tried to make it out of 1/8" sheet metal that I had laying around but I could not get it right so I used a thin wall 3/4 square tubing with a base welded to it that was made out of the 1/8" sheet - it was about three inches or so in length and one inch wide. The base was mounted on the floor of the bed by two 1/4" bolts and that's where the grounding straps were attacked under the bed to the frame and added a couple more to the cab to the frame. I later added on a cross piece welded to the mount making it into a "T" of sorts which was bolted to the bed. Nothing move that mount. The antenna was mounted on the top of the 3/4" tubing, once it had a base loaded whip and then I extended it up above the cab on the mount (added 1/2" tubing that slide into the lower one then welded that up) with a 5 foot whip on it. -
Man that sounds pretty nice! Gives me some ideas as well, I appreciate it. I moved mine from the front of toolbox, to the other side to give it some distance from cab plus it's easier access lol. Added 2 ground straps from toolbox to bed and got SWR to 1.3 across all channels. I'm pretty happy with it so far but I'm sure I'll be rearranging and adding to it lol. I'm using a 4ft k40 tuneable at the moment
Also seems like getting even more interference now that I wired to battery! Maybe the ground isn't good enough??
canadianredneck Thanks this.
