Tool for changing paper fuel filter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by biiqtruckin, Nov 6, 2017.
  1. biiqtruckin
    biiqtruckin Bobtail Member
    27
    Sep 20, 2017
    Do i need a 6 inch fuel filter wrench to change the filter on a detroit diesel 12.7 engine? Wonder if 5 inch wrench is enough for bottom and top cap? Thanks
    Its not the spin on but the other one on the other side.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Is that a Davco?
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,417
    6,430
    Aug 26, 2014
    Google: Davco filter wrench
  5. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,822
    Dec 7, 2015
    OK
    If this is what you have
    Then this is what you want
    Shaggy76, tony97905 and Cottonmouth85 Thank this.
  6. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    Make sure it is the small one and not the big one. Yes, there are 2 sizes. I have a new tech on the floor that did that a month ago when I told him to get his own wrench after I got tired of him borrowing mine every day.
    BigBob410 and Slowpoke KW Thank this.
  7. Slowpoke KW
    1,170
    12,822
    Dec 7, 2015
    OK
    Just learned something new
    Shaggy76 Thanks this.
  8. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    There is a 5 inch one with e blue handle and a 8 inch one for the Davco 482 filter system. Oddball setup used on the 2012 Detroit DD15 and 16. The most common is the 5 inch which is what the OP is wanting.
    Slowpoke KW Thanks this.
  9. Slowpoke KW
    1,170
    12,822
    Dec 7, 2015
    OK
    I haven't messed with anything newer than 2006 not too surprising they redesigned the fuel filters since they've changed everything else
  10. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    That's one thing I lived by when I was in a shop. If I had to borrow a tool more then once I always bought it when the took truck showed up! Nothing more annoying than a guy borrowing your tools all the time!
    spyder7723, 94yj and Slowpoke KW Thank this.
  11. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    I don't mind loaning tools out for the wages don't match the job these days. A lot of new techs out there can't afford them, but there is a limit as well. If you borrow it 5 times in 1 week, then I suggest by 2 paychecks to either get it off eBay or the expensive tool truck. Filter wrenches is one of those things that all the techs should have so that I give no excuse for. However, the Detroit tools for doing overheads, that's a bit more understandable. Or that $10k Allison rebuild tool set... I don't even have that one and I have a lot of tools. Some things I don't do enough to make it worth it to buy the tools, but I know who to borrow them from and I am sure to return them cleaner than I borrowed them along with a beer purchase $20 bill left on the tool box.
    Take care of the techs you work with and they will take care of you.
    BigBob410, spyder7723 and 94yj Thank this.
