TONU, please read about the trick
Discussion in 'Freight Broker Forum' started by 6wheeler, Jun 4, 2013.
  1. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    Truck Ordered-Not Used.
    Ok, so twice in the past week this has happened and the guy yesterday said he wasn't paying it, I still sent him a bill for it though.
    What story's does everyone have about this? How much do you charge for TONU?
    I would also like to add a trick that this guy played that I would like to pass along. 8 a.m. the truck is in route towards its pick-up and the phone rings.
    Broker asks, Hi hows its going, are you at the pick-up location? This I'm thinking its the broker checking up on me to see that everything is ok on my end for pick-up. So I tell him that I'm getting unloaded now and would be there for the pick-up within the hour.
    Broker was asking to see what kind of responce I would give, because he clamed the e-mail he got said it was canceled.
    Guess what, because I already told him that I was getting unloaded he didn't want to pay for TONU.
    Broker knows this deal isn't going to happen, but instead of maybe saying hey I'm sorry but this fell through will pay for TONU, he ask first before anything about where I am so maybe he doesn't have to pay.
  3. jfar28139
    jfar28139 Light Load Member
    192
    64
    May 28, 2012
    Rutherfordton, NC
    Generally accepted rule for TONU is that it isn't owed unless the truck is dispatched to the shipper. You made a mistake by not telling him the truth when he called.
    Fr8Life and KB3MMX Thank this.
  4. Marlin46
    Marlin46 Medium Load Member
    504
    299
    Mar 17, 2010
    Atlanta, GA
    6wheeler - Sorry to hear about your luck and hopefully you were able to get the truck back under a load quickly. The most I ever saw on a TONU was $175.00 and there was 6 trucks sitting at a shipper when the owner came out and said none of the product was going to pass QC. A few minutes later the broker called and said she was sending out TONU to all the trucks that were there. At least it was the truth about what happened when you see 6 trucks take off all pissed off.
  5. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    And why would you tell the broker your getting unloaded if your actually in route? Why not tell him your in route. Normally do not get TONU fee is truck is not in route or at the shipper. It is what you told the broker. This falls real close to getting detention and we all should know about collecting detention pay.
    The normal fee for TONO is $150 and this is not based on deadhead mileage. I haven't gotten more when the deadhead is really high but the miles do not normally change the fee. I've also gotten cheated out of it at the big shippers like the steel mills.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    The fee is whatever you agreed to when you accepted the load, and should be stated either in your carrier/broker agreement or on the rate confirmation for the load. The fee is negotiable and varies. If the truck has been dispatched by the broker and the load subsequently cancels, the TONU is due, regardless of your location or whether or not you've turned a wheel towards the shipper.
    Sly Fox Thanks this.
  7. 6wheeler
    2,696
    4,772
    Aug 30, 2009
    Ok, maybe I didn't fully explain. I booked a load on Friday that I was going to pick up Monday morning in Richmond VA. Monday morning I was on my way to Richmond to drop a load off, then pick up the other load that got canceled.
  8. 6wheeler
    2,696
    4,772
    Aug 30, 2009
    Thanks for the info. The truck was in route, in was in the city that the pick up was in, just dropping off a load on the way.
  9. karenrose
    karenrose Bobtail Member
    13
    6
    Jun 5, 2013
    If the broker doesn't pay, bill the shipper you were supposed to pick up from or deliver to if you have that info. Throw the broker under the bus! Shipper always has to pay! Regardless.
    6wheeler Thanks this.
  10. karenrose
    13
    6
    Jun 5, 2013
    Key to brokering is documentation. Broker should not dispatch a load without documents to support load so shipper can be help responsible. If broker dispatched without po or something from shipper, the broker is just not a good broker! (and you can bet won't pay tonu) Someone should and would have to pay if load was handled properly from the get go!
    If shipper has a habit of canceling loads, then all I can say is they are getting away with it by using brokers to take the fall for their mistakes and using brokers that scam drivers! Beware! I used to charge my customers 50.00 just to start a truck engine, whether truck left yard or had dead head miles or not. Theres a lot to consider in a tonu charge.
    Lay over with dead head could be a hefty, but fair, tonu.
    just saying...
  11. 6wheeler
    2,696
    4,772
    Aug 30, 2009
    I called both shipper and receivor. Shipper said yea that pick up number is good and its sitting out here in the yard, receivor said we don't have anything showing in our system that we ordered that stuff.
