I have 48' combo step, rated for 68,000 pounds.
Machine weighs from 45,300 to 47,300. So weight is not a problem. My cross members are 15" apart and I have diagonal supports at 5' from beam to outer rail.
My concern is the width between tracks. I've hauled excavators before I think the track gauge being 7.8' on this machine is wider than the ones I've hauled out of keenersville and a bit heavier.
Not sure if I'll be putting too much weight on the outer edge of deck.
Machine is a 1995 link belt 2800 excavator. Looked at it on Ritchie wiki.
Thanks in advance for sharing your wisdom.
To haul or not. 2800 link belt.
Discussion in 'Flatbed Trucking Forum' started by xsetra, Jul 20, 2016.
Page 1 of 6
@Hurst pulls a trailer like that.
Dominick253 Thanks this. -
I would do it. Would be better off on an RGN though.
Yes agree it would be better on an RGN. I already ordered permits so kinda sorta locked in.
I;m sure my trailer can handle the load. I had a paver bust thru my outer rails once between the axles and don't want to repeat the situation.
My trailer by the axles are 3/16 plate steel from side to side now.
Just asking for advice. Thanks.Dominick253 Thanks this. -
Thats kind of a toughy. I am not really familiar with the link belt 2800.
When I choose to haul a machine, generally I am pretty familiar with it from either hauling it back in the early 90's.. or later when I worked in construction.
When it comes to excavators I prefer not go much over 35k lbs on my trailer. When you rotate the machine.. the weight can be extreme from side to side. Step is not like an RGN where you can stablize it on the ground. You really need to know what you are doing when loading a larger excavator on to a step.
I think it can be done. Just need to be as gentle on the trailer as possible with that much weight outside the frame rails.
I personally dont think I would book one that heavy on my trailer. I might do a track loader or dozer in that weight range due to their limited ability to shift weight like an excavator can.
Be careful. Let us know how it worked out. Take some pics so I can see how it sat on your trailer.
I just got mine back.. and I must admit. I am a little skeered to abuse it like I had been.
HurstCruisingAlong Thanks this. -
If you boom up right it will balance out evenly, I boom up about half way then start to swing then adjust the boom until she levels out then you can swing 360 an it'l stay level.
Dominick253, truckdad and Ruthless Thank this. -
I always keep the stick tucked in with bucket curled up and the boom up just enough to keep the bucket from hitting the deck. Thats usually a pretty good sweet spot for most small to medium sized machines. The larger machines that step will never see can have much larger buckets and longer sticks that can and do offset the counter weight more than they should.
Or,.. if the machine has a heavier attachment like a hammer, hydraulic arm above the bucket,. this all adds weight. This is where experience comes in to play.
In any case,.. its a good idea to exhibit a lot of finesse with slow easy motions. If your level of of experience is minimal,.. I would turn the RPM's down to just above idle and just lug the machine. It will sound aweful on some machines when activating the hydraulics,.. but better safe than sorry and wont hurt anything.
I also wanted to add that its a good idea that once you lay the boom down,.. place some dunnage under the bucket ,.. then let the bucket out a little bit to touch the wood. Some machines,.. even brand new ones will allow the bucket to leak down during transport. Depending what you have touching the deck,.. this can cause damage to the aluminum on combo decks.
HurstLast edited: Jul 21, 2016
MACK E-6 Thanks this. -
MJ1657 Thanks this.
Page 1 of 6
