Tires ( cupping and wobble) questions..
Discussion in 'Experienced Truckers' Advice' started by sbatson, Oct 8, 2012.
  1. sbatson
    sbatson Light Load Member
    232
    10
    Feb 14, 2008
    Ft Worth, Texas
    Ok I have been in the same truck for a year now and its always wobbled and got to the point where it wore the tires in certain spots ( recaps). We have replaced all shocks, front rims,tires ( half recaps and virgin) and 2 rims in rear. The recaps seem to be cupping again but not the virgin tires and the wobble has gotten better but never went away. I have asked alot people about balancing the tires but it seems not to be necessary and I have never had to on other trucks. What is the freaking problem?
  3. TruckerJimbo
    TruckerJimbo Medium Load Member
    401
    377
    Oct 8, 2011
    Alabama
    Have you tried getting a 3-axle alignment? I had a wobble and uneven wear and that fixed it for me.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Leaf spring shackle bushings?
  5. Dump Truckin
    Dump Truckin Bobtail Member
    30
    6
    Oct 8, 2012
    Def bushings
  6. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    If you jack up the front axle do the front tires feel like they move top to bottom? if so its king pins...
    If the steering wheel has play in it or it feels like its drifting from side to side while driving it is spring bushings...
    But more importantly, are you running recaps on the steer axle?
  7. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    I had cupping issues but I got those centramatic wheel balancers and keep a good eye on my psi on all 10 tractor tires and have no cupping on my current set for the last 8 months.
    I remember my last set had one drive tire that had major cupping on it. I bought a used drive tire and that one did not "cup" at all. It seems like when the cupping starts it is hard to make it stop.
  8. EZ Money
    EZ Money Road Train Member
    I had the same problem on my rear drive axle.It had Bandag caps on that axle and virgin Michelins on the rest of the tractor.
    We got rid of the caps,put on new Michelin drives and a 3 axle alignment....problem solved.
    I had one axle that was off by 17 degrees so the steers were working against the other drive axles to steer straight.
    The truck drives way better and no more bobble trying to hold it straight on the highway.It is like driving a car now.
  9. BigJim1937
    BigJim1937 Medium Load Member
    303
    135
    Mar 27, 2012
    Fargo,ND
    cupping is caused worn bushings and they dont have to be worn to the point they are not there just worn unevenly. Replacing them should solve the problem. Recaps are made with a different rubber compound than factory originals are due to the process. That is why they cup more often and faster. For the money difference and the rate of wear I go with new tires never recaps on the trucks. Recaps are fine for the trailers but not the trucks.
  10. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    maybe I'm missing something, is this the steers that are cupping/wobbling or a drive? If this is the steers, another thing to look at it possibly a bad hub, that it's out of round. Had a problem where almost from new, mine had a wobble and ruined, flat spotted steers. It was aligned numerous times, tires balanced, rotated, etc., tire shop looked at it, king pins were replaced, didn't solve it, dealer had it three days before they diagnosed it as a hub that was out of round, miniscule amount, they replacd the hubs, problem solved.
  11. EZ Money
    I have got to the point where my trailer never gets caps either....I have had way less tire problems in the summer heat running all new rubber.
    Some recaps have casings that are just too old to have been capped.Some campanys are capping casings that are well past their useable life......really old date codes on them.
    In my case the bushings were fine,2011 model truck but the factory did a crap job of alignment when it rolled off the assembly line.
