Tire Wear Patterns Explained
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Heavyd, Sep 14, 2014.
  1. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
  3. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    All my drives with mega treads have heal to toe. By torque stress is that from accelerating with too much trq for the tread design?
  4. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yes, too much stress, or wrong tire design for your application. If you look at most drive tires with those big lugs, you will find "M+S" on the side wall somewhere. This is for Mud and Snow. It is basically an off road tire. If you operate on the highway most of the time, you are running the wrong tire.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    heal toe wear is common with most big lug tires some worse than others, rotating them frequently helps. i run lug tires and do a lot of off-road driving. certainly suited for my application and i still experience heal toe wear. so just cause they wear like that doesn't necessarily mean the wrong tire for the application just that that style tire tends to wear like that.
  6. Pool6710
    662
    258
    Aug 10, 2014
    Minnesnowta
    I run in dirt lots half of my day. Snow is always a problem in the winter as I drive in the twin cities. I still manage to get stuck with them though. They were only $2200 for 8 installed so oh well, had them for a year
    these tires don't like to stay balanced either, I had to put beads in all the drives to get rid of all the shakes.
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yep, tire pressure and tire rotation. Good advice!
  8. tesla4all
    tesla4all Light Load Member
    176
    33
    Dec 8, 2008
    Southeastern US
    Many thanks for this... there was a day when you would walk into most any big truck tire shop and there would be a huge poster on the wall with beat & wear pattern diagnosis.. don't see those any longer :(
    Heavyd Thanks this.
