Tire tread gauge, how do you read it?
Discussion in 'Experienced Truckers' Advice' started by mitmaks, Jan 26, 2019.
  1. mitmaks
    mitmaks Road Train Member
    2,541
    2,064
    May 16, 2014
    Bought a tire tread gauge however it has 3 different 32nds increments. Which one do I go off of?
  3. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    you just turn it to get the right reading. If you look it is 30/32 on one side then 31/32 on the next and so on.
  4. mitmaks
    2,541
    2,064
    May 16, 2014
    Im not sure what you mean? Turn gauge as I measure tire?
  5. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
  6. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Sorry no pull out the needle looking part then push it in the tread till the "T" part hits the top of tread. Then look to see which reading is just above the round chrome part. The reading that is closest to that is your depth. I suck at typing explanations hope that helped.
  7. Banker
    Banker Road Train Member
    4,003
    11,307
    Aug 19, 2012
    If you look closely the 3 increments are not at the same spot. Each is for a different tread depth. If it measures between the two you round down.
  8. mitmaks
    2,541
    2,064
    May 16, 2014
    I thought they were. My misunderstaning, I apologize
  9. Banker
    4,003
    11,307
    Aug 19, 2012
    That’s ok. I have to put my reading glasses on to see my numbers.
  10. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    In easy terms. You use them all. LOL
  11. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    Lead tires (steering tires, converter dollies for semi-trailers and steer axles on full trailers ) must have at least 4/32s tread depth at any point on any major groove except where tread wear indicators or stone ejectors are located. All other tires must have 2/32s inch in every major groove of the tire.
    PE_T and Lepton1 Thank this.
