There is the rule of not pairing tires as a dual with a difference of no more than 5/32. Is there a rule for tires placed on one side of the axle versus the other?
For simplicity, let’s take the example of a steer axle. On one side, the tire is at 5/32, and on the other, the tire is at 20/32. It seems like this may be acceptable, but perhaps it may cause inward tire wear on one tire and outer tire wear on the other. Now, the drive and trailer tandem axles are a more practical example than the steer axle. So, is there a general rule for this?
Tire Tread Depth Rule for Entire Axle?
Discussion in 'Ask An Owner Operator' started by PE_T, Dec 26, 2018.
PE_T Thanks this.
bzinger, HaulinConestoga, Long FLD and 1 other person Thank this.
I always did steers at the same time, I don’t have a specific reason for it. I don’t have any scientific proof but I would think a big difference from duals on one side to the other side would cause the differential to have to compensate for the size difference. I don’t know if that would be true or not, and I haven’t stayed at a Holiday Inn Express in a long time.
Opendeckin, HoneyBadger67, PE_T and 1 other person Thank this. -
Main thing when mounting duals is matching height. I’ve seen big difference in brands despite being same size. A shorter tire will skip and get flat spots
Reputable tire shops won't put tires of too great a depth difference on the same axle. i.e., if 3 tires on the axle are at 6/32 they won't put anything greater than 10/32 or 12/32 with them.
Rideandrepair and PE_T Thank this. -
Tire Wear | AcuTread Tire Service | Retreading Manufacturers -
I haven't seen a device like that since radials took over.
We were taught to use matching tread [had some funky trailer recaps] style for each side but no comparison to the other side of the axle.
But bias tires had flats so often that a lot of drive and trailer duals were changed frequently.
Flat tires used to be a REAL delay problem with Monday's being the worst.
Chemical Leaman tracked tires [loved to brand new tires!] by branding numbers which were used on tire change cards describing position and on/off numbers that was stapled to the RO going to the office. Pre-deregulation staffing allowed such minute bean counting.Rideandrepair Thanks this. -
