Okay, so the truck I'm purchasing this week has a tire size of 285/75 24.5, which I understand are low-pro 24.5's? Or am I wrong? I'm just wondering what my options are for replacing the tires on this truck, size-wise. Thanks for all the info!
Tire Size Options..? 285/75 245
Discussion in 'Trucks [ Eighteen Wheelers ]' started by smctransferllc, Feb 20, 2018.
You could change them to 11R 24.5 but there a taller tire.jamespmack and smctransferllc Thank this. -
If you put a 295 beside a 285 you will see no difference in size. Worked a couple of different truck tire shops for years coming up.
jamespmack Thanks this. -
First number is width in mm, second is aspect ratio, and third is wheel diameter
jamespmack, smctransferllc and snowman_w900 Thank this. -
You can put any 24.5 tire on 24.5 wheels,
Good luck with your new truck.smctransferllc Thanks this. -
I remember hearing—what is likely to be misinformation—that as long as the first number is the same, you can match a tire with the second number being no more than 5. My calculations are showing this is NOT true. Maybe for some tires this trick will work, but not on my tires.
