wat r the numbers u put in the ecm for different tire sizes? am running 11r24.5s wat r the numbers for them? the rest would be welcome
tire size input
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cat from the valley, Jan 1, 2009.
When programming the ECM it should ask for top gear ratio, rear end ratio, and tire size. This will translate into pulses per mile. Pulses per mile will tell the ECM how fast the truck is moving.
cat from the valley Thanks this.
Why not go to the source. The tire manufacturers all have their specs online.
tire manufacturers give specs for a new tire, they are about 473 rev per mile when you spec a new truck the computer they use give 476 as an average between new and somewhere before worn out.
cat from the valley Thanks this. -
i just went to good year and saw that so i figured that , thanks
am running a rtlo18918b wit 4:30 rears on 11,24.5 , i love that ratio
For the pulses per mile setting in the ecm, I think I remember that they take tire revs times a multiplier. The mfr. dealer can tell you what the multiplier is for your drive gear and trans.
oh lord more info still, am gonna mess wit the ecm tomorrow and i need all info
4.30 ratio x 16 teeth on rear output x 476 tire revs = 32749 ppm on a Cat ECM.
